I was thinking of getting this capture card, so I can play on my TV, while recording to PC.
http://www.amazon.co.uk/gp/product/B...pf_rd_i=468294
Would this work well and also, what extra connectors would i need to buy? The back of my TV has the following ports:-
HDMI
VGA/PC
SCART
YpcPr Audio L and R (Used by xbox 360 at moment)
PC Audio
Earphone
Rf In
Y, Pr, R (Used by xbox 360 at moment)
If this capture card is unable to work for this purpose, can I have cheap alternatives?
Thanks for reading.
Results 1 to 9 of 9
So you only want 720x576i output from your XBox?
You would plug the Xbox into a distribution amp, then run output 1 to your capture device and output 2 to your TV.
Composite
http://www.summitsource.com/cabletro...00-p-8397.html
Or S-Video
http://www.smarthome.com/8141S/4-Way...AV400SV/p.aspxRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Does the capture card im thinking of buying allow me to play in HD still and what is 720x576i output? Thanks for the quick response.
No. You would need to run the XBox set for SD out.Originally Posted by EvansslaughtRecommends: Kiva.org - Loans that change lives.
Oh ok. That doesnt bother me, but I have had a quick search for the amps, and I was hoping for something much cheaper. Im a student and have little to no money, hence the cheap capture card. Is there any other way to connect a capture card while still playing on my TV? They are both next to each other if that helps.
Consider this method for recording and watching HD from the XBox360.
http://forum.videohelp.com/topic378548.htmlRecommends: Kiva.org - Loans that change lives.
This is pretty much the same as what im looking at, but my price range is much lower. £40-£50 im hoping to spend. Im trying to find out is I could use a splitter to send the TV signal to my xbox and PC at the same time, playing in SD, recording it, and saving money on not using amps etc... and any extra connectors to use because of the splitter...
Thanks for all the help so far. Would this setup work? http://www.xbox360forum.com/forum/xb...taneously.html
It is a kluge but probably will get a signal to both places.
Baseband 75 ohm video is supposed to use an active splitter to maintain gain and frequency response.
Make sure the Easycap supports PAL60.Recommends: Kiva.org - Loans that change lives.
xbox 360 capture card?
By blindman96 in forum CapturingReplies: 7Last Post: 26th Mar 2011, 20:56 -
Xbox 360 Capture Card
By 23000 Empire in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2010, 08:51 -
Capture Card xbox 360
By Mastapka53 in forum CapturingReplies: 2Last Post: 27th Mar 2010, 13:50 -
By Dr Awesome in forum CapturingReplies: 2Last Post: 19th Feb 2010, 05:06 -
Best capture card for xbox 360?
By Edward1982 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2009, 15:53
