VideoHelp.com Forum
    Hi all,
    I'm a big fan of AutoGK. However, I recently ran into a situation where I'd like to set a specific resolution to my rip. However, the settings only allow you to specify width. I need to adjust the height as well. Is there any way to do so? If there's not in AutoGK, what would you recommend I do in order to adjust the resolution to what I desire, without sacrificing image quality?
    Thanks,
    Justin
  2. About all you can do is go into the Hidden Options and switch to ITU resizing. That'll often (usually?) give you a different height. I use ITU resizing myself, although at default settings AutoGK doesn't use it.
    There are a couple of add-ons that allow you to edit the AviSynth script, AutoGK Tweaker and AutoGK Pal:
    http://forum.doom9.org/showthread.ph...AutoGK+Tweaker
    http://forum.doom9.org/showthread.php?t=100517
    Other options include using AutoGK's much more configurable big brother Gordian Knot, or feeding an AviSynth script into the encoder and doing the whole thing manually. Doing it either way you can set the resolution to whatever you like.
    Hm. Thanks. I'll have to give all that stuff a shot later
  1. Adjusting xvid Soft Subs Size for dvd player?
    By spiritgumm in forum Subtitle
    Last Post: 27th Jun 2010, 12:39
  2. Adjusting frame rate on a slient film
    By fred3f in forum Editing
    Last Post: 8th Nov 2009, 18:44
  3. AutoGK : MPEG2 to Avi Frame Rate Problem
    By Mokkori Chan in forum Video Conversion
    Last Post: 27th Feb 2009, 03:51
  4. Replies: 11
    Last Post: 10th Sep 2008, 22:03
  5. AutoGK Settings: Frame Rate Confusion
    By Tom Saurus in forum Video Conversion
    Last Post: 30th Sep 2007, 05:18
