VideoHelp.com Forum
Results 1 to 29 of 29
    I have copy protected VCD which i wanna to rip and burn to a CD. But the problem is i cannot even see any data/video from my pc. The VCD is not faulty as i can play them in in a dvd player. Thanks in advance for those people that can help me.
  2. Member MOVIEGEEK's Avatar
    This has been discussed many times, there's a VCD copy-protection that's hard to crack.
    You should hit the SHIFT key when inserting the VCD then rip with IsoBuster, if IsoBuster can't rip it then you are out of luck.
    Where is the VCD from? India and Pakistan protect their VCDs with bad sectors and possibly also corrupt TOCs. Hong Kong, China, Taiwan and South Korea do not protect their VCDs. I mention that because if your VCD is not from India or Pakistan, you probably should try it on another PC and be sure that the problem isn't with your drive.
    If you search at the top of the Forum Index (searching only works at the top of the entire forum - it is broken within each individual section), you may be able to find some old thread we had maybe 2 years ago in the Authoring (VCD/SVCD) section that talked about this type of VCD copy protection and how to defeat it. If I remember correctly it was possible to copy such discs, but the process was complicated and required the user to have some understanding of VCD format.
    deleted
    Do u mean, i open Isobuster first , then hit and hold SHIFT key when insertign the VCD ? Thanks
  6. Member MOVIEGEEK's Avatar
    Hit SHIFT first, insert VCD, wait a few seconds then release SHIFT, then open IsoBuster.
    deleted
    My VCD comes from Singspore/Malaysia and is pretty old about 5 years ago.
    I have tried 2 PCs but to no avail. PC drive simply don't read the disc.
    China, Hong Kong and Taiwan do protect their VCD .
    http://yfrog.com/18capturerjkj
    See the link. ISObuster can see the data inside, but cannot rip them.. window explorer cannot even see the data. When i extract using ISObuster, its hang forever. Using alcohol 120% give me errors.
    Seems to me , no one can extract copy protected VCD, but only DVD.
    I just use cyberlink power DVD and is able to play the VCD. However how i can rip this VCD and copy into a blank CD ? Anyone kind soul here to provide a step by step guide and help me .
    Thanks in advance
    http://yfrog.com/18captureochj
    CloneCD fail to read the VCD !
    Singapore and Malaysia VCDs should NOT be copy protected! I was in Singapore 2 years ago and bought many VCDs. None of them were copy protected.
    China, Hong Kong and Taiwan do NOT protect their VCDs. You do not know what you are talking about. Most countries do NOT copy protect VCDs because it can cause playback issues. India and Pakistan are rather unique in protecting them.
    In fact, the more I read this thread, the more I think that you really do not understand what you are dealing with and as such you are extremely unlikely to ever copy the disc. I admit that I have had a few problems copying Hong Kong VCDs, and I rarely copy them, but those had nothing to do with copy protection and I was able to work around them.
    I had a VCD that had some protection like you and I could not read it with my computer.
    I've just tried to extract each track from "Track 02" with Isobuster and right click with "extract Track 02" and "Treat as video ONLY, Extract but FILTER only M2F2 MPEG Video Frame (*mpg)" option
    I've burnt the tracks with Nero as a VCD compilation and it played fine for me
  14. Member AlanHK's Avatar
    Not that I've ever noticed, and I live there. I've occasionally ripped VCDs, to convert to DVD format and add a subtitle. Just used ISObuster, or VCDGear.
    i tried the same thing as you. However , the extraction took forever. Always at "0 percent" .
    if the VCD arr not copy protected , can you kindly explain to me why my pc see no data in the VCD , but DVD player can play them and ISObuster can read the data. Why PC cannot see the VCD data. It is blank inside. Any kind soul here to explain this phenomenon to me .. Thank you very much
  17. Welcome to our forums, avatar123! You have rightly perceived that jman98 doesn't qualify as a "kind soul", as has been revealed in so many of his posts . . . . You have now joined many of us with first-hand knowledge.
    As a possible workaround, could you try playing it while using a standalone DVD recorder to capture the output? I tried that once, although it was a non-protected DVD, not a VCD. Probably a long shot if the DVD recorder recognizes the disc as copy-protected like most do for a copy-protected DVD and refuses to record. I've never had a commercial VCD for experimentation.
  18. Member AlanHK's Avatar
    I can only repeat: I live in Hong Kong, I have hundreds of VCDs, made locally, in China and Taiwan, and have NEVER had that problem.
    VCDs use a unique data format, unlike CDROM or audio CD. It could be a driver issue.
  19. Member fritzi93's Avatar
    I've done that a number of times, most recently a VCD of Egyptian antiquities my sister brought home. It was PAL and overburned.
    To the OP, have you read this:
    http://www.smart-projects.net/help.php
    Specifically on VCD:
    http://www.smart-projects.net/help.php?help=230
    Extraction options:
    http://www.smart-projects.net/help.php?help=130
    Have you run a scan first and created a managed image?
    Try a number of extraction methods, I feel certain that if the disc can be played, you can eventually recover the data. Note that you should try different drives if possible. Good luck.
    Pull! Bang! Darn!
    To all the guys trying to help me ... thanks to you.
    I manage to get CloneCD to duplicate it to a blank CD. And it work fine , i am happy , however the copied CD is still protected. PC still cannot read. But nevermind, as long as i have a backup and can play it in a DVD player i am happy.
    Despite what CobraPilot says, I am not always, ahem, "difficult" on these boards. Sometimes I am very blunt. And your statement that Hong Kong, etc. do copy protect VCDs is wrong.
    I am glad that you copied the disc. However, you had better options, which you ignored.
    1) I suggested that you search the forums for an old thread that covered this very topic and described how to copy a copy protected VCD and remove the copy protection. You apparently could not be bothered to try to find it. And I even told you how to do the search correctly (at the top of the forums) because searching is broken here if you don't do that.
    2) Nor could you be bothered, it seems, to read fritzi93's suggestions which also potentially could have given you a copy free of this copy protection, assuming it actually is copy protected.
    I find it interesting that CloneCD worked for you after you reported earlier that it did not.
    If your VCD somehow has copy protection, which I still find doubtful, then you have just about the only VCD from that region that is copy protected.
    Now you have a choice here. You can either be helpful to others who might read this later or you can go away. Your decision. Would you mind to answer the following?
    1) Is this a legitimate VCD or did you purchase a bootleg/counterfeit VCD at some stall? Is this on CD-R media or is it a legitimate commercial release that was pressed? If it turns out that this is some bootleg you bought that was overburned to 90 minute CD-Rs, well, it's certainly possible that we're all correct. You may indeed have a copy protected disc, but people like me and AlanHK are also correct in saying that commercial VCDs don't use copy protection in this region.
    2) Would you please tell us what the title is in case others in the future have this disc?
    I remain skeptical that this disc is copy protected, especially since you said you couldn't copy it with CloneCD and then later you could. I think the disc is possibly damaged or not really a commercial disc. But in any event if you would give back a little more and tell us what it is and whether it's really a commercial disc or not it would be helpful.
  22. Member AlanHK's Avatar
    Well, I've also seen lots of bootleg HK and Chinese VCDs and DVDs; and none of them have copy protection; however they could be non-standard or damaged in some way, as of course there is no quality control.
    A lot of people here play videos on PCs and laptops, so copy protection that prevented that would have customers demanding refunds.
    Also, bootleggers moved on to DVD some years ago as the production cost is virtually the same, and DVD player penetration is very high. It's been years since I've seen new bootleg VCDs on sale anywhere.
    Commercial ones though are still sold, I think because the licensing fee is lower for VCD than DVD, so they sell for about 1/3 the cost of the DVD release. So if it's a new VCD it's most likely legit. Five years ago, maybe bootleg.
  23. Member
    1) It is legitimate VCD .
    2) The title is in chinese character. Some chinese new year song which the people here would not be interested.
    3) I reported Clone CD fail when the drive when taking a long time read and indicated error in the meassage for the first approx 2-3 mins plus. But after i reported and after 3min , the drive continue to read using cloneCD and manage to rip the VCD. And I am happy.
    4) However the ripped disc is still copy protected and the PC still unable to read the data inside unless i use ISObuster , then i can see the data inside.
    5) Actually this is not the first copy protected VCD i enocunter. I think is the 4rd time. The last time i did some research but find it very difficult to rip and given up compare to a DVD which is some much easier to rip. But this time i decided to put in more effort to study ,ask question and research to solve the problem once in all ,so that in future if there is some more this type of copry protected VCD , i can rip without cracking my head.
    6) Usually it is more difficult to rip legitimate VCD coz the pc drive cannot see the data. IN the past i really reluctant to do it , but not for DVD coz there is so many tools and discussion availabe in the net for DVD. For those bootleg VCD, no problem ripping at all.
  24. Member
    We have Asian members. How do you know that nobody here would be interested?
    It took more effort to tell us that you aren't going to tell us what the title is than to have told us what it is.
  25. Member Cornucopia's Avatar
    Well, the last time I faced off with someone on this site who had a CP VCD, he was bragging that he could make them unbreakably CP.
    I was all, "put up or shut up".
    Then he was, "here's my CloneCD image. Burn it, try it, and cry, so FU"! (CloneCD is known to work in this way because of the ability to either IGNORE and/or PASSTHROUGH the disc's sector errors to a full RAW iimage)
    So I tried it, and got it ripped a few hours later (yeah, it did take that long).
    What you've got to remember is it's still all BITS. Using ISOBuster, a template-aware hex editor, and some other older CD image tools (CDMage, and a few others), you use the "EXTRACT FROM:TO" function and then search for non-zero, non-random, and non-sectorheader data. Compare that with what the disc is officially "telling" you is the sectors, and you can fairly easily see the skips, rerouting and offsets, etc. Then clean off the RAW (and bad) sector + mode info, and you've usually got a clean copy.
    That didn't even cover the failsafe of D -> A -> capture & re-record loop.
    As we've all heard before here, if it can be played it can be ripped.
    Note: Most VCD and some DVD players are VERY dumb and don't work on a "file system" level, they work on a raw sector level, which usually ignores the TOC lead-in and leadout pointers. This is where "smarter" devices get stuck; they're trying to
    play by the rules.
  26. Member
    [IMG]file:///C:/Users/Chishty/AppData/Local/Temp/moz-screenshot.png[/IMG]It seems copy protection of VCDs is very common for Indian films, but not so for mainstream Hindi films, because it can impede watching on computers. And today I came across a Telugu movie VCD, which was burned by a CD manufacturer called KRCD, and it is written on the CD that it is copy protected. When I tried to analyse the type of copy protection on Alcohol 120, it say it is an unknown copy protection. Even IsoBuster and cloneCD do not help, and when you try copying them, they are full of "read errors".
    These are the files on this copy protected VCD:
    Attachment 4723
    The Read me file has the following text:
    Instructions
    1. Run Install.bat from CD.
    2. Using Windows Media Player open the files in MPEGAV directory
    3. For uninstalling run uninstall.bat.
    Note:- Supports Windows Media Player, WinAmp
    Please make sure you have the latest DirectX package installed.
    And then the Install.bat file has this:
    @echo off
    if "%OS%"=="Windows_NT" goto NT
    copy /y IndyVcd.ax %WINDIR%\SYSTEM\IndyVcd.ax >nul
    start /w %WINDIR%\SYSTEM\regsvr32.exe %WINDIR%\SYSTEM\IndyVcd.ax
    goto DOREG
    :NT
    copy /y IndyVcd.ax %WINDIR%\SYSTEM32\IndyVcd.ax >nul
    start /w regsvr32 %WINDIR%\SYSTEM32\IndyVcd.ax
    OREG
    echo REGEDIT4 > %WINDIR%\cdxareg.reg
    echo. >> %WINDIR%\cdxareg.reg
    echo [HKEY_CLASSES_ROOT\Media Type\{e436eb83-524f-11ce-9f53-0020af0ba770}\{E436EB85-524F-11CE-9F53-0020AF0BA770}] >> %WINDIR%\cdxareg.reg
    echo "0"="0, 4, , 52494646, 8, 8, , 43445841666D7420, 36, 20, FFFFFFFF00000000FFFFFFFFFFFFFFFFFFFFFFFF, 646174610000000000FFFFFFFFFFFFFFFFFFFF00" >> %WINDIR%\cdxareg.reg
    echo "Source Filter"="{e8d8307c-a97a-11da-9584-00e08161165f}" >> %WINDIR%\cdxareg.reg
    echo [HKEY_CLASSES_ROOT\Media Type\{e436eb83-524f-11ce-9f53-0020af0ba770}\{A92227E7-22F0-42f4-B6A4-C788839BB32F}] >> %WINDIR%\cdxareg.reg
    echo "0" = "0,4,,52494646,8,4,,43445841,60,8,,44554D4D5920202 0" >> %WINDIR%\cdxareg.reg
    start /w regedit /s %WINDIR%\cdxareg.reg
    del %WINDIR%\cdxareg.reg
    The VCD can be played on WMP and Winamp, but not on VLC media player. So can somebody try to find out a way to remove this copy protection?
  27. Originally Posted by lexchief View Post
    Attachment 4723
    Instructions
    @echo off
    goto DOREG
    :NT
    OREG
    This seems to be the similar protection that I came across on a VCD today. It wont allow me to copy files. It used a protection so that you can play it on PC exactly as you describe ie via windows media player. I got real angry with this stupid bad sector based protection system...anyways reading through this form, provided me the answers.
    Here is what worked for me...I deduced that since WMP is playing file without any problem, the video files should be error free and kept isolated some where in the CD.
    So all you have to do is install IsoBuster [beg/borrow/steal :P]
    Hold down shift key while loading disc into drive [to prevent autorun]
    Open isobuster. Simply right click "Session1" and choose "Extract but...only MPEG files" option. Extractn process starts > wait for an error dialogue to appear. In that, at bottom there will be "Quit....." checkbox, check it and choose the quit button in the err dialogue.
    So IsoBuster searches only for the good error free video files and recovers them while skipping all the errorfile junk they put in..simple as that!
    Do let me knw if this helped!
  28. Member Cornucopia's Avatar
    ...Like we've been saying all along, "If it can be played, it can be copied".
    (Who would knowingly add such a DLL/REG rootkit anyway? or allow it to be run?)
  29. Member fritzi93's Avatar
    Yeah, the VCD my sister bought of her Egypt tour group had that. Footage of her and her friends, mind you, and the VCD they all buy at a premium price won't play on her DVD standalone. Yeah, PAL issue, but did they have to pull that anticopy crap? Just another annoyance while I made her a playable DVD-Video copy. Plus the audio was shit, I had to fix that too.
    BTW, IsoBuster (select extract mpeg) does the trick.
    Pull! Bang! Darn!
  1. Replies: 3
    Last Post: 16th Jul 2010, 21:15
  2. Will a DVD player play any files but DVD/VCD and CD audio?
    By brassplyer in forum DVD & Blu-ray Players
    Last Post: 24th Sep 2008, 19:32
  3. Replies: 2
    Last Post: 13th Jul 2008, 12:15
  4. DVD will play on new DVD player, but won't play on old
    By joe8915 in forum Video Conversion
    Last Post: 18th Feb 2008, 18:57
  5. Replies: 1
    Last Post: 22nd Oct 2007, 14:33
