If you own the Vixia HG21, or similar Canon Vixia models, please advise on what settings I should go with manually. Also, should I use that software that came with the camera Imagemixer 3 SE or something else?
I just bought my HG21 last week. Really nice camera. I plan on doing some freelance news work with it.
Anyhow, I've found that the bundled software isn't really worth it, unless you are uncomfortable with computers. It's easily replaced with a better program like RipBot264.
What the Imagemixer software will do for you is give you a GUI for transferring files from the HG21's HDD to your computer (which you can do manually).
It also allows you to convert .mt2s files, but it only converts to a standard def format, which makes no sense to me. RipBot allows you to convert .mt2s files into several different file types, at multiple resolutions and framerates.
Help with Canon vixia HF M41
By Gerrysw in forum AudioReplies: 11Last Post: 27th Apr 2012, 23:12 -
Canon VIXIA HF G10
By wingspar in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 12th Dec 2011, 16:18 -
Using the Canon Vixia HG21 as a webcam.... is this possible?
By Heyjoojoo in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 28th Dec 2010, 22:55 -
Difference between Canon Vixia HF-20 vs Canon HF-S20?
By Wink in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 20th Nov 2010, 16:46 -
Canon VIXIA Cameras?
By Ron B in forum Camcorders (DV/HDV/AVCHD)Replies: 20Last Post: 20th Feb 2010, 17:33
Statistics
Newest guides
Latest tool updates
New media comments
