VideoHelp.com Forum
  1. XP with MPC-HC
    What tool should I install?
    I've seen DirectVobSub which is vsfilter.dll. I'd need to register it manually. Not sure if it will work with other software or interfere with Haali Media Splitter.
    The other option is VobSub. However, I've learned in the past that it screws up the aspect ratio of the video. You'd have to manually force an aspect ratio.
    Thanks!
  2. I'm a Poll Super Moderator johns0's Avatar
    You shouldn't need to install anything to have the subtitles showing,mpchc will display the subtitles itself.
    Ben Johnson-I didnt take any stereos!
  3. I have subtitle saved as srt file with the same filename as the video file. However, it's not showing the subtitle. The subtitle submenu is greyed out. Is there any option?
    Thanks!
  4. I'm a Poll Super Moderator johns0's Avatar
    Maybe theres something wrong with the srt,try another srt and see if it displays,just move the other sub out and put a good sub in and name it the same.
  5. The output was set to System Default. When I change it to VMR9 (renderless), the subtitle works.
    What's my system default?
    Thanks!
  1. Replies: 1
    Last Post: 19th Jan 2012, 07:36
  2. Replies: 0
    Last Post: 9th May 2011, 08:15
  3. Playing Video on display 2 and display 1 goes black
    By sidewaysdriver in forum Software Playing
    Last Post: 3rd Aug 2010, 00:36
  4. Do not display changed subtitle.
    By manjularoshan in forum Subtitle
    Last Post: 8th May 2010, 04:35
  5. media player can display subtitle-all video format?
    By binocular222 in forum Newbie / General discussions
    Last Post: 18th May 2007, 09:24
