Hi all !
My purpose is to convert only movie track from DVD but with several audio tracks and subtitles WITHOUT re-ripping MPEG2 video for PS3 playing...
I thought I could do so :
1- As tsMuxeR read only SRT subtitles as input : I create SRT file(s) from VOB DVD files with DVDsubEdit or SubRIP
2- With tsMuxeR, I select the first VOB, join the other VOB files to the first one into input list, add SRT files I want and then select audio tracks I want to keep
3- After choosing the good language for all audios and SRT tracks selected, I run tsMuxeR for M2TS output
All runs fine, but when I run movies in my PS3 :
-I have no language indications for audio
-I have no subtitles seen by PS3![]()
Any workaround for these mysteries ?![]()
Thanks by advance
Tried multiavchd?
Thanks for your fast answer. I have not yet tried 'multiAVCHD', but I have done many different tests today and I think multiAVCHD could be the right solution...Originally Posted by Baldrick
In fact, I found that there is no problem with tsMuxeR in creating multi stream M2TS with several srt files and several audio streams... But PS3 simply cannot use them and runs only the first video stream and the first audio stream encountered and no PGA stream at all...
To run correctly these 'more than two' streams M2TS files, PS3 needs absolutely a 'BD authoring' file structure and suddenly : all runs fine ! A simple AVCHD structure goes well.
So I think (reading what it makes) multiAVCHD is THE RIGHT IDEA to create à multi movies AVCHD structure filling a whole BD-R with several independant movies with different streams contents following user needs.
It keeps to me to DL multiAVCHD, learn using it correctly and ... I can dream my 'special need' will have found its right solution !
Still thank you Baldrick and I will keep this topic informed from results...
Slightly overwhelmed...wanting to do DVD (episodes) to m2ts or mp4 for PS3
By trimicada in forum DVD RippingReplies: 7Last Post: 15th Oct 2009, 11:25 -
Playing multiple m2ts files on PS3 from a DVD
By dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jun 2009, 09:47 -
m2ts for PS3 on USB stick or DVD
By leopardx in forum Media Center PC / MediaCentersReplies: 2Last Post: 14th May 2009, 09:56 -
m2ts (vc-1) streaming to ps3?
By Browncoat in forum Media Center PC / MediaCentersReplies: 4Last Post: 16th Jan 2009, 01:06 -
Problem converting mkv to m2ts (for PS3)
By scift in forum Video ConversionReplies: 8Last Post: 16th Dec 2008, 17:22
Statistics
Newest guides
Latest tool updates
New media comments
