Just installed today.
Tried everything mentioned in this prior thread...running Win7 home.
http://forum.videohelp.com/topic378049.html
I exported to a folder, and opened mpeg with winmedia center, showtime. MP Classic and it plays; just would like the preview window in V2M to play also.
Tried Dscaler really dont want to run Dscaler, plus-do you just run it? then use Preferred Filter tweaker?
Ran this but all it says is all codecs Mircrosoft-no options to change to.As you have Windows 7: can you run Preferred Filter Tweaker and set the MPEG2 preferred option to DScaler5 MPEG-2 decoder? You may need to reboot thereafter
I must be missing something....
any other tips?
Thanks, T
Hi. Its not DScaler the program its DScaler5 the codec. If you install that then you will have that option in Preferred Filter Tweaker (should you need it).
Alternatively - i have just uploaded a new build which allows you to try alternative DVD players in the Settings:
If you are having this issue with Type 2, try Type 1 (or vice versa)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Understand on the Dscaler info, will go get new build of Vob2MPG, many thanks, TOriginally Posted by ChrissyBoy
Ok, I have the new build installed and it autoplayed when .ifo loaded.
However, no sound...install more codecs?
Thanks, Chrissyboy
Just install ac3filter and you should be good
Did it and audio!Originally Posted by ChrissyBoy
Again, Thank you
T
VOB2MPG PRO - Video comes out pixelated
By freak6148 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th Jun 2011, 11:05 -
Video preview not working in VOB2MPG PRO new build 3.0.0700
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th May 2010, 14:44 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
vob2mpg cannot play back video stream error newest verison
By Wizard23 in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 7th Jan 2010, 17:17 -
slow pans are jerky on DVD after Premiere Pro exports
By spicediver10191 in forum Authoring (DVD)Replies: 15Last Post: 6th Nov 2007, 20:59
