Please critique and let me know if I'm doing anything wrong :thanks:
NLE Sony Vegas 9C
Render output as:
Video: 29.970 fps, Project Frame Size Progressive
Pixel Aspect Ratio: 1.000
Cineform settings:
Source file media info:
ideo
Format : CineForm HD
Codec ID : CFHD
Codec ID/Info : CineForm 10-bit Visually Perfect HD (Wavelet)
Duration : 26mn 4s
Bit rate : 106 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 1.711
Stream size : 19.4 GiB (99%)
HCEncoder Settigngs:Code:AVISource("F:\MakPlaydenoiseTest\Makdenoised.avi",pixel_type="RGB32") ConvertToYUY2() ColorMatrix(mode="Rec.709->Rec.601", clamp=false) LanczosResize(656,448,0,1,1920,1078) AddBorders(32,16,32,16) ConvertToYV12
Everything else left at default except Fox1 for matrix
Mediainfo for HCencoded file:
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 5mn 33s
Bit rate mode : Variable
Bit rate : 4 799 Kbps
Nominal bit rate : 8 000 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.463
Stream size : 191 MiB (96%)
Writing library : |HCenc 0.23.0.0 - (c) 2004/2008|
This assuming that HCencode is better then TMPGenc 4 xpress which I also have but unsure of proper workflow
Thanks again!
Results 1 to 1 of 1
Correct Project and Sequence Settings for footage from Panasonic TM300?
By Bloodredthorn in forum EditingReplies: 0Last Post: 20th Jan 2012, 12:34 -
The correct way to crop and encode anamorphic DVDs?
By harbourshin in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2011, 21:32 -
Correct Settings in Image Burn for HD-DVD?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 17th Jan 2009, 17:01 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 14:29 -
Correct settings for encoding video for the 'new' YouTube format?
By Captain Satellite in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2008, 17:45
