DVD player is from a home-cinema set called LG LH-T751TB. http://www.lge.com/products/model/de...h-t751tb.jhtml
USB memory stick is a 8GB Kingston DataTraveler 120. FAT32(I have tried NTFS also)
It recognizes MP3 and JPEG files and plays them fine, but when I have (only) XVID files on the memory stick, the DVD player says "No data".
Please help. Thanks in advance!
More info about the XVID file:
Results 1 to 12 of 12
[EDIT]
Nevermind.
[EDIT]
Thanks for a fast reply!
Any solutions? What should I convert my videos to then?
dvd.
maybe try avstodvd or the film machine.
[edit] sorry i assumed it couldn't play divx/xvid. i should have checked the op's link myself. carry on....--
MOVIEGEEK - Appreciate you trying to help, but you should have noticed that the "review" you linked to has ZERO reviews in it, so what you have is in effect a placeholder and NOT IN ANY WAY reliable information. Theodorist provided a link from LG that says that the player does indeed play Divx.
Theodorist - Thank you for providing the screen shot. That is most helpful. My guess is that probably packed bitstream in your Divx file is a problem. You can remove it with MPEG4Modifier without having to re-encode. Also you posted in the wrong forum. This should have been in the DVD & BluRay Players forum. Finally, please go here and read this:
http://forum.videohelp.com/topic352457.html
Anything in this list may be a problem for your DVD player.
I would also cut that AVI file down is size and burn it to a test CD(as DATA) to see if the player recognizes it. Looking at the specs for that player....Xvid and Divx are listed under types of DISCS played.
I'll move this to the DVD Player forum.
I tried unpacking the bitstream, didn't help.
Then I burned the xvid file to a CD. The DVD player recognized the file and I could play it. It just stuttered like hell(might be due to the scratches on the CD).
Also try converting the audio to 44.1 instead of 48. I have an hard drive based player attached to my TV and audio is always the culprit with lack of playback issues.
Can you recommend me a program for that?
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 06:16 -
Disc of Xvid files work on DVD Player but not PC
By MattG in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 05:43 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 11:10 -
PSP doesn't recognize format
By rqthrottle2 in forum ffmpegX general discussionReplies: 5Last Post: 6th Jan 2008, 13:32 -
Ulead DVD MovieFactory 6 - Doesn't recognize DVD
By urlilgurl017 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 12:52
