VideoHelp.com Forum
Results 1 to 30 of 46
    I have Panasonic LCD TV TX-L32U10E. It has SDHC slot for displaying images and to play video. I browse internet for 3 days and didn't find any information for the supported codec. The only information about was mentioned AVCHD and H.264 codec with mpeg4 and mts ot m2ts formats. I downloaded trial converter and convert trailer in ts (H.264 HD codec) and mp4, but when move SD card in the TV it says: "no recognizable files" or something...
    I didn't find any converter to make mts file to test it. As I understand this files are available from Sony or Canon cameras.
    My question is is it possible to convert avi (xvid or divx) file to any supportable format, and then watch it on my TV?
    You can make avchd m2ts using avchd coder and multiavchd.
    But I guess you have just tried avi xvid/divx files and they don't work at all?
    Yes, I try xvid/divx and they don't work. I readed somewhere that panasonic support team mention that they will support divx in later products.
    I will try to convert m2ts file with avchd coder, and will post the result.
  4. Member MJA's Avatar
    download demos/short clips and try them
  5. Member yoda313's Avatar
    Check panasonics website for your tv. There is a chance they have a converter utility that will convert videos for your exact format.
    I checked. There is no information for the supported format. Only in the manual is mentioned dvb-t (mpeg2 and mpeg4-avc(H.264)) support.
    I am downloading baldrick's links and will try other formats.
  7. Member MOVIEGEEK's Avatar
    I believe all Panasonic TV's and BD players only support AVCHD from a camcorder, my BD35 and BD60 have a SD slot and that's what the manual says.
    Did you mean that I can't convert video and play it from the SD card?
  9. Member MOVIEGEEK's Avatar
    Unlikely, Panasonic requires a very strict AVCHD structure from a camcorder that nobody has been able to figure out yet.
    http://www.dvinfo.net/forum/avchd-fo...card-slot.html
    I have a Panasonic TV and used and got fed up converting files. So I now use a Western Digital Media Player box.
    It just plugs into any TV and plays most file formats from an external hard-drive or sd card slotted into a card reader. The device has 2 USB slots and works a treat to plug anything into it.
    I dropped the Panasonic SD card slot as limited gimmick and love the WDMedia Player.
    http://www.amazon.co.uk/gp/product/B...03NNSFQB9RVY67
    I also drop the sd card slot. Too much noise for nothing. Suddently I have no usb. But have 2 hdmi... When Panasonic start to support divx, things will be great
  12. for panasonic viera tv multiavchd will work i have tested it on my plasma it converts the vdeo for viera standard. i have enjoyed teh full hd videos on my plasma through sd card.
  13. i can give u the converter with step by step tutorial if anybody needs it.
    go ahead
  15. Here are the snapshots of steps - Snapshots.zip
  16. Originally Posted by MOVIEGEEK View Post
    That is not true, since I figured it out and for the last year multiAVCHD is the only free tool which can create the proper output for SDHC both in Viera and Panasonic BDP players (along with the SD_VIDEO MPEG2 format).
    Dean
    edit: @kocu/kode: I see you're Bulgarian (like me) so you can PM if you want help.
    Laugh and the world will laugh with you. Cry and you will be alone
  17. Member MOVIEGEEK's Avatar
    Dean
    I stand corrected, the last time I tried multiAVCHD on a SDHC card it didn't work on my Panasonic BD35.
  18. Member
    Somebody already find a whay to converts AVI for AVCHD for PANASONIC VIERA CDHC CARD TV ???????
  19. The only way is to transcode the DivX/XviD AVI file to H.264/AVC. And the only tool that will allow you to put the correct structure on a SDHC card is multiAVCHD. Simply put there is no other tool for that.
    dean can you sei what´s dath:
    [00:50:08] Initialising...
    [00:50:08] Checking for new version...
    HttpQueryInfo: 12019
    [00:50:10] You have the latest build.
    [00:50:10] Consistency check finished!
    [00:50:10] Initialization finished. multiAVCHD is ready!
    [00:50:10] 1 year and 110 days since multiAVCHD was published.
    [00:50:10] Support multiAVCHD to extend its features and keep it going!
    [00:50:10] multiAVCHD.dat version: [04000746]
    [00:51:00] Loading external subtitles: (und) - smallvill.srt
    [01:00:43] Checking for available space and drive types (FAT32/NTFS)...
    [01:01:00] Destination [c:]: NTFS, 50691.45 MiB (49.503 GiB) free space
    [01:01:00] Temp folder [c:]: NTFS, 50691.43 MiB (49.503 GiB) free space
    [01:01:00] Log started for multiAVCHD v4.0 (build 746)
    [01:01:00] Selected output mode: Panasonic Viera TV (SDHC) (PAL)
    [01:01:00] Processing one title...
    [01:01:00] Existing c:\multiAVCHD\AVCHD\ cannot be used as destination folder!
    [01:01:00] Output will be written to: c:\multiAVCHD\AVCHD-20100415-010100
    [01:01:00] Processing (C:\Users\eldiablo\Desktop\smallvill\smallvill.avi )...
    [01:01:00] Pre-processing AVI file...
    [01:01:00] This title is marked for reencoding / uncropping...
    [01:01:00] Encoding process may take 10 min to 10 hours, so be patient...
    [01:01:00] *** Initiating video encoding:
    [01:01:00] *** Original : 624x352
    [01:01:00] *** Crop : 0
    [01:01:00] *** Resize : 720x480
    [01:01:00] *** Uncrop to : 720x480
    [01:01:00] *** Sharpen : 0
    [01:01:00] *** Bitrate : 1030 kbps
    [01:01:00] *** Frame rate: Original (23.976)
    [01:01:00] *** Level : 3
    [01:01:00] *** B-frames : 3
    [01:01:00] *** Ref-frames: 4
    [01:01:00] *** GOP size : 48 (keyframe min. each 4 frames)
    [01:01:00] *** Quality : One pass (turbo)
    [01:01:00] *** SAR : 40:33
    [01:01:00] *** DAR : 853x480
    [01:01:00] *** Profile : Blu-ray
    [01:01:00] *** Encoding : One pass - content: [00:41:44]
    [01:01:00] *** Encoding : x264 options: --preset veryfast --bitrate 1030 --interlaced --direct spatial --keyint 24 --level 3 --min-keyint 8 --bframes 3 --ref 4 --subme 2 --mvrange 256 --partitions p8x8,i8x8 --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 12500 --vbv-maxrate 12000 --qcomp 0.5 --threads auto --thread-input --aud --nal-hrd vbr --sar 40:33 --b-pyramid strict --slices 0 --weightp 0 --qpfile "c:\multiAVCHD\_TEMP\multiTEMP-20100415\IDR-x264-marks.txt" --rc-lookahead 24 --output "c:\multiAVCHD\_TEMP\multiTEMP-20100415\smallvill.[720x480-23.976].264" "C:\multiAVCHD\tools\20100415-010100-uncrop-running.avs"
    [01:01:00] *** Speed : 1277359.66 fps (elapsed: 00:00:00 - Realtime x 53276.6)
    [01:01:00] *** Transcoding failed!
    [01:01:00] *** Check ffdshow/avisynth/haali (reinstall)!
    [01:01:00] *** DEBUG: Try to play [C:\multiAVCHD\tools\20100415-010100-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
    [01:01:00] Retrying to transcode with FFMS2!
    [01:01:00] Stand-by for indexing...
    [01:01:00] *** Stand-by for indexing (ffms2)...
    [01:01:00] *** Speed : 349045.95 fps (elapsed: 00:00:00 - Realtime x 14558.14)
    i cant puth in the sdhc card tv can you help
    [01:19:07] Initialising...
    [01:19:07] Checking for new version...
    [01:19:09] You have the latest build.
    [01:19:09] Consistency check finished!
    [01:19:09] Initialization finished. multiAVCHD is ready!
    [01:19:09] 1 year and 110 days since multiAVCHD was published.
    [01:19:09] 280 people supported it with donations
    [01:19:09] and you are the 1483656 one to launch the program...
    [01:19:09] Support multiAVCHD to extend its features and keep it going!
    [01:19:10] multiAVCHD.dat version: [04000746]
    [01:19:49] Loading external subtitles: (und) - smallvill.srt
    [01:28:22] Checking for available space and drive types (FAT32/NTFS)...
    [01:28:38] Destination [c:]: [01:28:38] Temp folder [D:]:
    [01:28:38] Log started for multiAVCHD v4.0 (build 746)
    [01:28:38] Selected output mode: Panasonic Viera TV (SDHC) (PAL)
    [01:28:38] Processing one title...
    [01:28:38] Existing c:\Users\eldiablo\Desktop\smallvill\AVCHD\ cannot be used as destination folder!
    [01:28:38] Output will be written to: c:\Users\eldiablo\Desktop\smallvill\AVCHD-20100415-012838
    [01:28:39] Processing (C:\Users\eldiablo\Desktop\smallvill\smallvill.avi )...
    [01:28:39] Pre-processing AVI file...
    [01:28:39] This title is marked for reencoding / uncropping...
    [01:28:39] Encoding process may take 10 min to 10 hours, so be patient...
    [01:28:39] *** Initiating video encoding:
    [01:28:39] *** Original : 624x352
    [01:28:39] *** Crop : 0
    [01:28:39] *** Resize : 720x480
    [01:28:39] *** Uncrop to : 720x576
    [01:28:39] *** Sharpen : 0
    [01:28:39] *** Bitrate : 1030 kbps
    [01:28:39] *** Frame rate: 25.000 (23.976)
    [01:28:39] *** Profile : SD-DVD (MPEG-2)
    [01:28:39] *** Encoding : Two pass - content: [00:41:44] (MPEG-2 encoder: HCenc)
    [01:28:49] *** Speed : 6567.35 fps (elapsed: 00:00:09 - Realtime x 262.69)
    [01:28:49] *** Transcoding failed!
    [01:28:49] *** Check ffdshow/avisynth/haali (reinstall)!
    [01:28:49] *** DEBUG: Try to play [C:\multiAVCHD\tools\20100415-012839-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
    [01:28:49] Retrying to transcode with FFMS2!
    [01:28:49] Stand-by for indexing...
    [01:28:49] *** Initiating video encoding:
    [01:28:49] *** Original : 624x352
    [01:28:49] *** Crop : 0
    [01:28:49] *** Resize : 720x480
    [01:28:49] *** Uncrop to : 720x576
    [01:28:49] *** Sharpen : 0
    [01:28:49] *** Bitrate : 1030 kbps
    [01:28:49] *** Frame rate: 25.000 (23.976)
    [01:28:49] *** Profile : SD-DVD (MPEG-2)
    [01:28:49] *** Stand-by for indexing (ffms2)...
    [01:28:49] *** Encoding : Two pass - content: [00:41:44] (MPEG-2 encoder: HCenc)
    [01:28:58] *** Speed : 6665.96 fps (elapsed: 00:00:09 - Realtime x 266.64)
    [01:28:58] *** Transcoding failed!
    [01:28:58] *** Check ffdshow/avisynth/haali (reinstall)!
    [01:28:58] *** DEBUG: Try to play [C:\multiAVCHD\tools\20100415-012849-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
  22. As the log says, you need avisynth, haali media splitter and ffdshow installed.
  23. Member Wam7's Avatar
    Thanks for the info contained here. I've just got a Panasonic 50" plasma and was wondering how to use the SDCard slot. I still might get a WDTV for simplicity but will try out encoding to AVCHD.
  24. I do not understand... I followed the steps and i am not able to play AVCHD (.mts) file on my TX-L32u2E. Do i need to put the file in some special folder (as is the case on sd audio players)? Is there something that i am missing here? like an extra step?
  25. Member
    Like I said on an earlier post, the aggrovation is not worth it.... to me a failed panasonic sd system being non user friendly.
    Using as I do a Western Digital Media Player box instead for the past 8 months, putting nearly any video onto a usb memory stick from a computer it can be put into my WDMP and viewed on my TV in a couple of minutes. Also video clips on a SD card without converting to AVCHD and be played straight away using a usb card reader put into my WDMP, which also has its own remote control as well.
    Also the WDMP can be taken and plugged into any other persons tv in minutes to view anything on a usb memory stick, sd card with usb card reader or on my 250 gb hard drive.....
    The best little user fiendly investment I have bought in years...no more converting video files or disc burning to view video from my computer onto my large home TV.........to me the Panasonic sd card slot......forget its not worth the time and efffort even trying to convert files to AVCHD with limited success.......I know I have tried and now no longer have to even bother anymore.
  26. I do know that WDMP is like 100 times better than sd card slot, and i have laptop with broken hdmi port which i have to repair and a DVD player with usb port. but i just want to try and play something on that slot.. just to see that it is working. so far i tried to follow the exact structure of the AVCHD folder. I just wanna know how to play any video on that slot.. I was unsuccessful using multiAVCHD. I would like to know if someone has a newer panasonic camera to tell where and in which format are the movies saved.. Also i read somewhere that software used to edit and transport videos from panasonic camcorders is called HD writer ae 2.1 or 2.0 (depending on the year). How did you play videos earlier on the SD card slot? considering that you ever did.
  27. I don't have any problems with my Panasonic Viera with structures created with multiAVCHD.
  28. Member
    Jimmi, I did use the multiAVCHD system of converting a few files with success, but was shown the WDMP bought by a friend. This rendered the panasonic folly of going through all the trouble of converting files to view on my tv with multiAVCHD POINTLESS.
    Not now having to bother converting files to view on my tv with a WDMP, has got to be better than having to even consider going through endless time wasting file conversions when you do not have to.......
    My WDMP makes watching video files the simplest way possible for me at the moment on any tv, what else can I say...... no disc burning or file conversioning...........I plug my 250gb hard drive into it and I have instant access to all my home movies and any other video files. also photos and music files..........
    If you wish to use muitiAVCHD which does work with some effort, just follow the web site info...its not simple but with time and effort you may be lucky converting something to watch in the end as I did.....I can`t remember the exact points to convert to play it on an sd card in my panasonic tv as I gave up with it on seeing the WDMP perform my objective with so much ease.
    Follow the mulitiAVCHD site info if you must ...it does work...and good luck.
  29. I have successfully converted movies using muliavchd - an amazing program.
    http://multiavchd.deanbg.com/tutorial.php
    BUT
    Once converted, I get a Blu-Ray folder structure.
    e.g.
    MOVIE ----AVCHDTN
    |---BDMV
    | |--- Stream
    |--- 00000.m2ts
    etc.
    Is there any way to have the Viera TV (in my case, TC-P50GT25) read and play the whole thing as a Blu-Ray?
    Or can I only just play the .m2ts files individually?
    Thanks.
  1. panasonic viera xseries mp4 porblem
    By bensonoommen in forum Video Conversion
    Last Post: 17th Feb 2012, 12:52
  2. Panasonic Viera TX-P42UT30B - MKV Playback issues
    By nathan1990 in forum DVB / HDTV
    Last Post: 20th Dec 2011, 05:25
  3. SD card for panasonic viera
    By gamergaz in forum Capturing
    Last Post: 25th Nov 2011, 19:31
  4. Panasonic Viera TX50V20 TV will not play AVCHD
    By dobien in forum Newbie / General discussions
    Last Post: 19th Jul 2011, 09:47
  5. Panasonic Viera with Dynex DVD and FIOS Remote question
    By zumata in forum DVD & Blu-ray Players
    Last Post: 21st Feb 2011, 13:23
