ok im new to this so im going 2 lay down what iv done and hopefully make it make since
i have a back of a movie on my pc that actaully got destroyed. i started doing this ever since my 5 month old got a hold of our dvd case and back them up 2 burn them incase he gets his hands on anymore.
this is what i did. so i used SUPER c to convert the file to DVD Std. compliant (VOB). it conveted it into 1 VOB file.
heres where i think i messed up. i went ahead and burned that single VOB file 2 dvd using nero. and tried to play it. im reading now thats not what im suppose 2 do.
i read on another forum im i could use a program called rejug 2 demux the single VOB file into more than 1 file (4 what reason i have no clue) and then i can use nero 2 burn it 2 dvd but when i try 2 deumux with this program ReJig it wont let me pul up the VOB file
lol as u can see i must be completly lost. any help would be great
Results 1 to 13 of 13
Thread: question on vob files
my last post got locked but the movie i downloaded was in fact a back up of twilight my 5 month old son got a hold of so no worries guys. i did indeed own the original copy
i thought when i converted to vob that was dvd cause on the selection of formats to convert 2 it said dvd/vob.
so u actually have to convert 2 vob then 2 dvd?
VOB is a container. It's the container that DVDs use for the audio/video/subs, etc. But to make a movie DVD you need all the appropriate support files in the proper layout -- IFO, BUP, VOB. You need to use DVD authoring software create all the supporting files.
ahh ok. im trying dvd flick. it appears to do that. does the file always have 2 be vob to use it cause it looks like its able 2 encode it on the fly
sry all the questions guys but ur a biiiig help
What ends up on the DVD will have to be VOB files. But DVD Flick can convert other A/V file types to MPEG 2 in VOB.Originally Posted by rtr720
ok dvd flick is done. it created a file it named DVD
and inside that theres 2 files called audio ts and video ts. video ts has a bunch of stuff in it but audio doesnt have anything
im guessing its in correct format now 2 burn? i just take all the stuff in video ts and burn those im guessing?
1 last 1 4 clarification. i burn the entire video ts file correct ? that should work? lol super noob
Yes, add the VIDEO_TS folder. ImgBurn will recognize you are burning a VIDEO_TS folder and use a special mode for burning movie DVDs. You don't absolutely have to include the AUDIO_TS folder.
thanks so much 4 ur help and patience. i think iv got it. U ARE AWSOME!!!
use imgburn. put it into "build" mode. click the browse for a folder icon and choose the folder containing your audio and video ts folders. insert a blank dvd. select your destination drive. set the speed of burn you want. click the build arrow.
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Question about editing VOB files
By C0SM0 in forum EditingReplies: 19Last Post: 26th Feb 2008, 18:53 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 01:05 -
Question on conversion from VOB files to MPEG4
By donkeyking in forum Video ConversionReplies: 8Last Post: 17th Jul 2007, 16:56
