VideoHelp.com Forum
    Hello,
    I would like to know if there is a way to find out who created a photo if the information does not show in the general properties of the photo. This relates to photos that have been created by scanning a printed document to a photo format.
    For instance, it says a HP Scanjet was used & Picasa software but the author is blank. Is there any way of finding out who the author would be in hidden info on the photo?
    HB
    This is information is called "metadata", and it is not necessarily always filled out. So if the author category is blank, it is likely that it was left out.
    I use adobe bridge to view metadata, but I'm sure there are other viewers
  3. Zilla God Des's Avatar
    Irfanview can be used to read and write the data.
    Unfortunately for metadata and EXIF info, is that it can be changed or deleted by someone else who has access to the files at anytime.
    --dES
    "You can observe a lot by watching." - Yogi Bera
  1. Replies: 2
    Last Post: 4th Jan 2012, 01:44
  2. What are the top "photo and video to dvd" creation tools?
    By extent in forum Newbie / General discussions
    Last Post: 8th Sep 2010, 17:04
  3. changing the creation date of your avi file
    By billkater in forum Editing
    Last Post: 1st Apr 2009, 06:46
  4. Problem with x264 lossless file creation
    By algee2k8 in forum Video Conversion
    Last Post: 28th Oct 2008, 10:55
  5. Does Avi2Dvd only support creation of ONE file?
    By m93 in forum Authoring (DVD)
    Last Post: 21st Jul 2008, 03:16
