Hi everyone,
I have recently installed Windows 7 on my PC,but I seem to be having some difficulties with the sound card. At first I installed the sound card's drivers from the cd that came with the PC(the one that has everything you need for your motherboard). Then I tried to play up some mp3 songs,but the sound is crap(sorry for using this word,but I do not know what else to call it.From some research I made with the google's search engine, I think it is called "distorted".It is sometimes funny but I really want to listen to my music in normal form)
This is some info I get from the components in sytem information about my Sound Device.
Name Unimodem Half-Duplex Audio Device
Manufacturer Microsoft
Status OK
PNP Device ID MODEMWAVE\0\{2B548A23-97E1-4500-92E8-3912B1E101EF}
Driver c:\windows\system32\drivers\modemcsa.sys (6.1.7600.16385, 18,00 KB (18.432 bytes), 14/7/2009 2:55 πμ)
Name SigmaTel High Definition Audio CODEC
Manufacturer SigmaTel
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_8384&DEV_7618&SUBSYS_80862113& REV_1002\4&1488D858&0&0201
Driver c:\windows\system32\drivers\sthda.sys (5.10.5067.0, 1,12 MB (1.177.032 bytes), 12/1/2010 6:20 μμ)
I do not know what's wrong but I really want a solution to this.If there are more info needed for the solution of this problem tell me how to find them and I will copy them up here.
Thanks in advance
Results 1 to 11 of 11
those aren't soundcard devices. look in control panel sound to see what is your default device. also right click computer/properties/devices to check if any are listed with a unknown yellow flag.
go to your motherboard manufacturer's website and download win7 drivers.--
my manufacturer's webiste is intel,and there is nothing for my PC,I think it was discontinued or something. I use the Sigma Tel soundcard but I can't seem to find it's model ID.
in the device manager is it listed? or are there yellow triangles and unknown devices?
it may be too old to work in win7 if there are no current drivers.--
What aedipuss said. That file you posted appears to be the audio drivers for your modem, not your sound card. Generally W7s own sound drivers work without adding any extra drivers. I've been using the W7 default audio drivers on three W7 PCs with no problems.
But if they don't work, you need to identify what brand and model your sound card is and look for W7 drivers for it. AFAIK, W7 handles sound differently than earlier OSs and does most of the audio processing with the CPU, so older drivers may not work properly.
Here is the model
SigmaTel STAC9227X @ Intel 82801HB ICH8 - High Definition Audio Controller [B-0] PCI
I can't find the drivers though :/
EDIT
It is listed in the Sound,video,and game controllers of device manager
As SigmaTel High Definition Audio CODEC . The only thing that is not installed is PCI Simple Communications controller(which I think hasn't got anything to do with the audio)
looks like sigmatel was bought out a couple years ago. no vista or win7 official drivers. i'd try http://catalog.update.microsoft.com/...%20sigmatel%22 this search and see if microsoft has anything.
if not a google search turns up a coupe of drivers you could download and try but not many people have any luck getting that audio chip working properly in win7.--
Not exactly the best solution, but if no working drivers seem to be available and if you have a spare PCI slot, it might be easier to just get a newer audio card that would have W7 drivers easily avialable.
hmmm...I was thinking about redwudz's suggestion before even starting up this topic :P That catalog has got many drivers. It wouldn't be wise if I started installing them one-by-one and see which one actually works. Anyway aedipuss your help was great
I haven't seen such fast replies to questions of mine,with actually a working solution :P So if I go with a new one which one should I buy from here http://www.eshopcy.com.cy/PER_soundcards.phtml ? The cheapest one or something a bit more expensive? What things do we usually look for in soundcards?
if you have a pci slot the creative xfi is an ok card. i have one in my 32 bit win7 machine and it works fine.
OK Finally I have found the problem
I had installed the newer updates from microsoft and it wasn't working,so I pushed the "roll back driver" button and everything is fine
Oh yeah !
I can finally hear to some music. Thanks for the help guys
Is There Really A Linux That's easy to use for Windows User?
By wulf109 in forum ComputerReplies: 60Last Post: 24th Mar 2012, 17:48 -
Video does not show in Windows XP limited user a/c
By lahratla in forum Software PlayingReplies: 0Last Post: 23rd Mar 2010, 04:15 -
No sound problem - internal tv capture card
By planetx in forum CapturingReplies: 1Last Post: 5th May 2008, 04:38 -
Linux questions from a Windows/OS X user
By LSchafroth in forum ComputerReplies: 18Last Post: 2nd Apr 2008, 23:36 -
PCLinuxOS The easiest linux there is for a windows user who wants to try.
By betamaxman in forum LinuxReplies: 0Last Post: 8th Jun 2007, 23:20
