Would someone know how to decipher garbled subtitle texts? I've found several at AllSubs.org with the following message: "Please note that due to encoding the texts may look garbled. If you believe this is the right subtitle please type in the 3 digit and letter code at the bottom." How would I go about decoding the text? And how on earth does one know if the texts are right when the preview says, for example, "00:01:39,579 --> 00:01:42,414
Ãû âûñòóïèòå âìåñòå ñ DyBre à à ýòîé ñöåà å."
I would greatly appreciate any help with this mystifying problem. This is the first time I've posted a question to this forum although not the first time I've used it and found answers to my problems, for which many thanks!
Thread: Garbled subtitle texts
What that's most likely referring to is the encoding necessary to display text in other languages (for example, Japanese). Most language encoding uses extended ASCII/double-bit characters or Unicode, and will be displayed properly if you have the system set to display those languages.
If you're just looking for English subtitles, you don't need to worry about that. Just pick the subtitle choices that show English dialogue, of course.
That's what I would normally have thought but AllSubs (or the uploader) says that the subtitles are in English. They obviously made a mistake. I did post a question on their site but to no avail. Thanks for your speedy reply though.
disabling Closed Caption Texts
By pskim in forum SubtitleReplies: 2Last Post: 5th Aug 2007, 11:36 -
DVDR offscreen texts
By Digiface in forum DVD RippingReplies: 0Last Post: 19th Dec 2006, 04:47 -
moving texts and windows in Ulead DVD workshop's menu's?
By Mkm in forum Authoring (VCD/SVCD)Replies: 2Last Post: 14th Nov 2002, 16:20 -
Garbled Divx
By zarad in forum MacReplies: 0Last Post: 5th Aug 2002, 16:59 -
How to erase written texts from movies?
By mach in forum Newbie / General discussionsReplies: 2Last Post: 29th Sep 2001, 01:46
Statistics
Newest guides
Latest tool updates
New media comments
