VideoHelp.com Forum
    I have a monitor with a dvi and a vga output. Im trying to play and record on one monitor so that i can just swtich from vga to dvi. I am using a hdmi to dvi cable but the problem is when I plug this into the out of the blackmagic intenstiy pro I get an "out of range" picture even though my monitor supports 1024x720 resolution. Is it possible to play and record and the same time on one monitor and just switch over from digital to analog for me?
  2. Member edDV's Avatar
    I can't make heads or tails from what you are saying.
    Xbox360 exports 1280x720p or upscaled 1920x1080i and BM Intensity Pro ony accepts those resolutions over analog component.
    Your 1024x720 native HDTV should accept and rescale the looped analog component 1280x720p or 1920x1080i so what is the problem?
    http://www.kiva.org/about
    Im sorry I meant 1280x720. The thing is when I plug my monitor into the output of the bmip I just get a black screen.
    Its also a monitor not a HDTV and I am using a hdmi to dvi cable to connect my monitor to the output of the BMIP.
  1. Will this computer handle the BMIP?
    By WILDWAYNE001 in forum Newbie / General discussions
    Last Post: 10th Nov 2010, 19:46
  2. Bmip?
    By WILDWAYNE001 in forum Capturing
    Last Post: 8th Nov 2010, 17:59
  3. BMIP Audio out of sync?
    By fonebone10 in forum Newbie / General discussions
    Last Post: 15th Apr 2010, 16:37
  4. HD PVR + xBox360 + PC Monitor
    By frool in forum Capturing
    Last Post: 16th Mar 2010, 13:51
  5. code error in xbox360 while playing a movie
    By d2idan in forum Media Center PC / MediaCenters
    Last Post: 16th Jun 2008, 23:03
