VideoHelp.com Forum
    Attempting to connect this wal-mart brand TV to my toshiba sdv295 DVD/VCR Combo player...
    there are only 2 composite cable plugs and one co axle cable plug in the back of this tv...Here in is the problem...My toshiba sdv295 DVD/VCR Combo player has the 3 composite cable plugs but the tv only has 2...So onto plan b...I bought an RCA to Co axl cable converter in the hopes that this would fix the problem...It didn't...Any ideas on what needs to be done?...Thanks again...
    bump...
    Do you mean that your TV has 1 audio and 1 video input connector and the combo unit has 2 audio (L and R) and 1 video output connectors? If so, go to Radio Shack and you can buy what they call a "Y connector" which accepts 2 RCA inputs (look up "RCA jack" online if you don't know what that is - it should be what you are talking about) and can provide one male RCA output that will go into the TV.
    By the way, weekends are bad times to post here looking for help, but if you weren't one of those "post my question and then leave when I get an answer, never to return" type of users you'd know that. I'm not trying to insult you, but I call them as I see them.
    Thanks...I'll try that...
    Didn't work...waste of money...
    I checked some specs on your DVD/VCR. Possible that the connectors that are being referred to "Combo player has the 3 composite cable plugs" are really the component plugs. They are usually color coded blue, green, and red. On the other hand, depending on the type TV and age, if it does not have those plugs, possibly the composite video ( color code yellow ) and audio ( color codes white or - red and white if stereo ) are what will work. If there are still questions, a model more specific than Wal-Mart brand tv would be helpful in trying to help.
    I see the player also has S-video output but it is possible that the tv in question does not have them either.
    If the device referred to as "an RCA to Co axl cable converter" is actually also called RF modulator, that should provide a solution.
    AKA here: http://www.radioshack.com/product/in...ductId=2103095
    I hope one of these will help.
  1. DVD Recorder/VCR combo
    By tj1182 in forum Capturing
    Last Post: 1st Dec 2009, 20:52
  2. VCR/DVD combo with RF output?
    By tac7 in forum DVD & Blu-ray Players
    Last Post: 5th Jan 2008, 11:17
  3. Help deciding for VCR/DVD combo
    By UltW in forum Newbie / General discussions
    Last Post: 2nd Oct 2007, 21:45
  4. Best VCR OR VCR/DVD COMBO for restoration
    By demonwarrior in forum Newbie / General discussions
    Last Post: 24th Aug 2007, 02:02
  5. Magnavox combo DVD/VCR/TV
    By DSedon in forum DVD & Blu-ray Players
    Last Post: 19th Jul 2007, 11:36
