My old TV only has component input, and the placement requires a longer cable than they supplied. Does anyone make a 3.5 mm plug to component video, as well as the 3.5 plug to L,R, and Composite video cables.
Or has anyone successfully used a Male to Female extender stereo cable into the WDTV Live box and then use their crummy proprietary cables attached to the extension?
Help! Otherwise it works great, but no HDMI on the current set, so I need to stretch that signal!
Thread: WDTV Live - Longer cables needed
Used the SEARCH function , above, and came up with this:
http://forum.videohelp.com/topic374280-90.html
you mean 3.5mm jack to rca ? you can buy those pretty much everywhere.
http://images.kenwood.eu/files/image...al/CA-C3AV.jpg
I've successfully ran a 45 foot component cable to my video projector with no problems. I got it from Monoprice. http://www.monoprice.com/home/index.asp They may also have a 3.5mm to component adapter, but probably easier to use 3 female to female RCA adapters with the stock WD adapter.
Simple ... forget about the 3.5mm plug part, just grab longer rca cables and a rca connection adapter allowing you to join the rca cables to extend them.
Only use rca cables long enough to do this ... those devices are not very powerful as compared to pc to tv setups which can use 50'+ cables without problems.
WDTV Live (non Plus)
By stiltman in forum Media Center PC / MediaCentersReplies: 181Last Post: 12th Jun 2010, 17:46 -
Asus O Play vs WDtV Live
By xobituaryx in forum Media Center PC / MediaCentersReplies: 11Last Post: 8th Jun 2010, 14:47 -
DTS on WDTV LIVE?
By bagmand22 in forum Media Center PC / MediaCentersReplies: 3Last Post: 28th Jan 2010, 11:09 -
Help with few WDTV Live questions
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2010, 06:34 -
WDTV Live - 5.1 Audio
By yamatosoul in forum Media Center PC / MediaCentersReplies: 1Last Post: 25th Nov 2009, 17:35
