VideoHelp.com Forum
  1. Hello Ladies stiltman's Avatar
    Is there a program like Gspot that will work with MKV H.264?
    Specifically, one that will list SAR/PAR/DAR. and one that scans the file, just not the header.
    MediaInfo only lists 16:9 or 4:3
    Originally Posted by jagabo
    try avinaptic, which will give you a bit more information, but it uses slightly different terminology (FAR = frame aspect ratio)
    mediainfo will be enough most of the time, since you have the frame dimensions, and the DAR , you can figure out the PAR (in h.264 terminology , SAR is the sample aspect ratio , which is the w:h of the pixels , traditionally it was called PAR or pixel aspect ratio). If the file was encoded with x264, it should print the --sar x:y value in the header information
  3. Hello Ladies stiltman's Avatar
    Here's an example:
    The original file was
    MPEG2
    720x480
    SAR 1.5
    PAR 1.85
    DAR 1.778
    Encoded file:
    Format : Matroska
    File size : 1 017 MiB
    Duration : 1h 19mn
    Overall bit rate : 1 791 Kbps
    Writing application : HandBrake 0.9.4
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Container profile=Unknown@3.0
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 19mn
    Bit rate : 1 262 Kbps
    Width : 720 pixels
    Height : 400 pixels
    Display aspect ratio : 16/9
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
  4. Additionally... mkvinfo from MKVtoolnix.
    VideoAudio.pl - Serwis o technologii wideo & audio
  5. Hello Ladies stiltman's Avatar
    Here's and example of why I would like to see more info
    Both of these video were in coded from the same source using Handbrake.
    The only setting that was changed was Anamorphic strict and auto cropping
    Anamorphic stricted with auto crop:
    Video
    Format : AVC
    Duration : 1h 45mn
    Bit rate : 1 494 Kbps
    Width : 720 pixels
    Height : 468 pixels
    Colorimetry : 4:2:0
    Writing library : x264 core 79
    Anamorphic strict without any cropping:
    Video
    Format : AVC
    Duration : 1h 45mn
    Bit rate : 1 487 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Standard : NTSC
    Both videos show up as the exact same size on the monitor and TV. Both have the right aspect ratio. So something is setting the SAR/PAR/DAR that I can not see.
    If I turn off anamorphic strict, the aspect ratio is wrong
    I'm not sure what handbrake does, but you can either set the display flag in the container (e.g. mkv) , or encode the --sar x:y value into the video stream. Handbrake uses a modified version, because the information is missing.
    For #2, it could be either container flag 16:9 or --sar 32:27 , you won't know unless the data is in the header , or you look at the stream
  1. muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
    By codemaster in forum Video Conversion
    Last Post: 20th Sep 2011, 20:50
  2. haali media - use custom media type for h.264
    By adom in forum Video Conversion
    Last Post: 15th Mar 2011, 05:07
  3. Replies: 4
    Last Post: 27th Apr 2010, 11:41
  4. MKV H.264 settings
    By stiltman in forum DVD Ripping
    Last Post: 12th Oct 2009, 14:20
  5. Replies: 4
    Last Post: 18th Jul 2007, 09:25
