VideoHelp.com Forum
    I've just registered here, and am not very computer literate, so apologies. Here's my question:-
    I’ve been making DVD clips for my teaching work with DVD Shrink 3.2. My clips are all VIDEO-TS files which I keep in folders. (I find this less fussy than book marking and carrying around DVDs, as the all clips can be kept on one memory stick). The problem is that the clips seem to slow down and some start freezing about an hour into the session. (It's almost as if they get tired!) Has anyone had this problem, and do you know if there is a way to fix it? Thanks in advance to anyone who can help.
    SLow down and freezes when you play it on your computer? or standalone dvd player? or something else?
    And are you playing them from the memory stick? Same problem if you try play them from the hdd?
    Thanks for reply, Baldrick. Yes, the slow down and/or freeze happens when I play the clips on my Vaio laptop. (I show the clips through a multi-media projector connected to the Vaio) I still get the same problem if I play the clips from the Vaio hard drive.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    It may be an overheat problem with the laptop. Try running a program like HWMonitor during playback: http://www.cpuid.com/hwmonitor.php It could be overheat with the on-board video chip or the CPU. You should also check the CPU usage with Task Manager during playback as something may be running that is slowing down the system at the point where the playback slows down.
    If those same clips play correctly on other systems, then there seems to be something in the laptop that is the cause. If all clips do it at the same interval, then a hardware problem would be my first guess. And overheating of the GPU or CPU may be the reason. If you've had that laptop for a while, the thermal paste on the CPU may be getting old, or it may have a bit of dust clogging the cooling system.
    And welcome to our forums.
    redwudz, thank you. I'll do what you suggest. (And thanks for the welcome!)
  1. Video Causing Computer to Freeze
    By Ownaholic in forum Software Playing
    Last Post: 26th Apr 2012, 12:10
  2. .avi movies freeze when video is saturated
    By HartsVideo in forum Software Playing
    Last Post: 9th Dec 2010, 13:34
  3. Slow buffering, video files ...
    By SharonMary in forum Newbie / General discussions
    Last Post: 16th Aug 2010, 07:20
  4. Video Freeze after Conversion to NTSC
    By gcam in forum Newbie / General discussions
    Last Post: 1st May 2008, 10:57
  5. Replies: 22
    Last Post: 16th Mar 2008, 13:56
