VideoHelp.com Forum
  1. I run filmerit and found I have over 400 codecs. I've deleted about 50 from Roxio and there are still 350+ left. I've been having a lot of problem with stability on video playback lately.
    How do I clean up the house?
    Thanks!
  2. Member AlanHK's Avatar
    Look in the Tools section under "codecs"
    http://www.videohelp.com/tools?toolsearch=codecs
    Several codec management tools are listed.
    They are under the codec/video identifiers section, try more tools like CodecInstaller, Codec Tweak Tool, dxman.
  5. Mod Neophyte Super Moderator redwudz's Avatar
    I'd give the suggested software a try. If the problems persist, and seem to still be codec related, then consider a re-install of the OS. If you have installed a lot of codec packs, they don't always un-install cleanly and sometimes starting over with a clean OS install is the easiest way to fix it all in one step.
    I usually put ffdshow in a new computer and it handles most video formats without using any codec packs. Any other needed codecs can be installed individually. If you just need playback of odd formats, VLC works well. Then I sometimes add Real Alternative and Quicktime Alternative players for those formats.
  6. How can I tell which one to keep and which one to delete?
    thanks!
  7. Member olyteddy's Avatar
    Take them all out and do as redwuz sez.
    "I usually put ffdshow in a new computer and it handles most video formats without using any codec packs. Any other needed codecs can be installed individually. If you just need playback of odd formats, VLC works well. Then I sometimes add Real Alternative and Quicktime Alternative players for those formats. "
  8. Member AlanHK's Avatar
    thanks!
    Use one of the tools to deactiate all of them and start clean, it's the best way.
    Just add codecs as you need them.
    I use one of the codec packs, K-Lite.
    If you use it carefully it can simplify things. Its installer lets you choose exactly which codecs to install and uninstall (including ffdshow).
    People have problems if they install "everything", or even worse, install multiple codec packs, then you end up with multiple versions of the same codec all over the place and broken players.
  1. help to clean up old videos
    By Bulldog57 in forum Restoration
    Last Post: 1st May 2012, 04:39
  2. What's New In Video Clean-up
    By Teac23 in forum Restoration
    Last Post: 23rd Apr 2012, 06:16
  3. What do you use to clean your system?
    By Banleno007 in forum Computer
    Last Post: 17th Feb 2012, 18:51
  4. Keeping them clean!
    By willmoodom in forum Portable Video
    Last Post: 22nd Dec 2007, 20:05
  5. wiped clean
    By aanfield in forum Newbie / General discussions
    Last Post: 26th Jun 2007, 14:12
