I am having problems with the auto film feed on this projector. When I turn the projector to forward or reverse neither the front or back reels move and the film does not seem to auto lace when i feed it into the slot can anyone help
Thread: Sankyo Dualux 1000 Projector
Have you opened up the case and checked to see if all belts, idlers are in place and that the drive motor is turning? I imagine there is also some sort of tensioning mechanism that controls reel rotation and that may be slipping or not engaging. Or the belts may be stretched and slipping.
You might also go to Sankyo's website and see if a service manual is available.
One service/user manual possibility: http://office.manualsonline.com/manu...alux_1000.html
One source for belts: http://stores.ebay.com/PROJECTOR-BELTS-SUPER-8-8MM-16MM
And welcome to our forums.
Hello Grumpypaul Did you find the answer to your problem, I have the same model of projector and am having exactly the same issues with mine. hope you do not mind me asking.
I cleaned a closet yesterday and found my dualux projector all boxed up. Haven't used it for at least 16 years! I have all of the original equipment, including the cover and the manual. Here are a couple of things from the manual that might help with your issue...1. set the format selctor knob to the type of film you're using - Regular 8 or super 8; 2.make sure you have a good film tip (cut if necessary); 3. set the rotary control switch to "FWD" position; 4. Press the loopsetter guide (when the rotary control switch is set at "FWD" position and the guide is pushed all the way down, the guide will remain in closed position for threading operation); 5. Insert the film tip into the auto-load slot. release your hold on the film as soon as you feel a slight tug indicating that the feed rollers have taken up the film. CAUTION: The auto-load slot will not be accessible for the introduction of the film tip if the RAPID REWIND LEVER is pulled out (it has an "R" on it and pushed inward). I no longer use this machine nor intend to so if any of you will pay the postage, you may have the complete machine, manual, cover and all.
Hi Grmadon,
Do you still have the dualux?
I would love to have it!
Bill
Sankyo Dualux 1000H and Super 8 to DVD
By murihikukid in forum Newbie / General discussionsReplies: 1Last Post: 5th Jun 2011, 02:27 -
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 12:02 -
new HD projector
By mgrig in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:01 -
PS3 and my Projector not getting along.
By StoneColdWhat in forum DVB / HDTVReplies: 7Last Post: 16th Feb 2008, 18:00 -
What resolution projector do I need?
By Xenogear900 in forum DVB / HDTVReplies: 5Last Post: 26th Oct 2007, 12:56
