Following the VirtualDub help files I wanted to set my format to YUY2 (I think) and then use the Huffyuv compression codec as it is highly recommended.
When I try to set the custom format to YUY2 I get an error "The Capture device does not support the video format"
The device I am using is "Microsoft DV Camera and VCR (DirectShow)".
So I thought I could just change to the "Microsoft WDM Image Capture" device. When I try this VirtualDub hangs.
What am I doing wrong?
You're capturing from a DV camcorder, Canopus ADVC, or similiar? Just capture as DV AVI. That's an exact copy of what's on the tape (or comes out of the ADVC).
capturing from a DV camcorder. I was just trying to optimize the compression so I can tame the file size.
Re-read jagabo's post. DV-AVI is the EXACT data that is on the DV camcorder. You are merely doing a digital transfer from tape to computer. Select a DV codec (Cedocida is recommended -- and must be installed separately) and capture.
You don't really even need a DV codec for capture.
Converting from DV to HuffYUV will increase the file size -- except in some rare circumstances (like an all black video).
Need a set of hi-res custom matrices for 90 - 110 min avi's...(details)
By bxmbxm in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Jan 2010, 17:18 -
different compression virtualdub
By chewie8008 in forum EditingReplies: 14Last Post: 8th Aug 2009, 12:45 -
Virtualdub compression
By quxote in forum Newbie / General discussionsReplies: 25Last Post: 26th Jul 2009, 07:59 -
virtualdub compression for dx50?
By majax79 in forum EditingReplies: 4Last Post: 22nd Dec 2007, 21:51 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 11:14
