VideoHelp.com Forum
  1. Member yic17's Avatar
    Hi, I am using my Hauppauge HD-PVR to capture my PC gaming for the first time.
    My Hauppauge HD-PVR auto detects the Input Resolution as 1920 x 1080.
    But the highest resolution I can get in-game is 1600 x 900 ... so I want to capture at 1280 x 720 instead.
    There doesn't seem to be an option to change the Input Resolution to 1280 x 720.
    What can I do so my HD PVR captures the PC at 720p?
    Thanks.
  2. Member edDV's Avatar
    Thanks.
    You need to output 1280x720p analog component from your PC display card.
    http://www.kiva.org/about
  3. Member yic17's Avatar
    ah! I found it in my Nvidia Settings. Thanks =)
    My computer 1920X1080, but my Hauppage input says 720x480. How did you get your PVR to record at 720? Right now it's at 480 and i cant seem to fix it.
    Yup
    Are you using composite or s-video cables? That's all those can carry. You must use component video cables to capture HD.
  1. Capture Software for Hauppauge HD-PVR
    By DarrellS in forum Capturing
    Last Post: 25th Mar 2012, 12:59
  2. I can't capture in 720p with my Hauppage HD PVR
    By Lotus Prince in forum Capturing
    Last Post: 25th Jan 2012, 23:34
  3. Replies: 8
    Last Post: 9th Jan 2012, 00:26
  4. Replies: 3
    Last Post: 21st Aug 2011, 04:14
  5. Replies: 17
    Last Post: 5th Sep 2008, 06:41
