I keep getting this error on some movies.
DirectShowSource: couldn't open file E:\temp\RipBot264temp\job1\video.mkv:
The system cannot find the file specified.
(E:\temp\RipBot264temp\job1\getinfo.avs, line 2)
Im using the latest versions of the software needed to run ripbot. Have tried re-install etc and no luck.
Thread: RipBot error?
You might look through this guide and get some possibilities: http://forum.videohelp.com/topic358185.html#1898786
Similar to this?:
If you receive an error in Ripbot264 like Code:
DirectShowSource: Couldn't open C:\temp\RipBot264temp\job1\video.mkv:
The selected folder/file was not found
(C:\temp\RipBot264temp\job1\getinfo.avs, line 2)
then if you are in Windows Vista, you have to disable UAC(User Account Control) and run as administrator. See here.
Or try rip the Blu-ray to your HDD first(see here) and then open the m2ts from the HDD.
Or try use tsmuxer to open the main movie mt2s(the biggest file) from the Blu-ray, create a new ts file and then open the new ts in Ripbot264. Read this detailed Blu-ray to MKV guide: http://forum.videohelp.com/topic362452.html for more information how to use Tsmuxer.
RipBot Demuxing Error
By F.Garvin in forum Blu-ray RippingReplies: 2Last Post: 22nd Feb 2011, 18:07 -
Sudden RipBot error (avisynth error)
By Charles314 in forum DVD RippingReplies: 5Last Post: 24th Oct 2010, 01:44 -
Ripbot error
By Bazza-61 in forum Blu-ray RippingReplies: 5Last Post: 20th Oct 2010, 08:25 -
RipBot Error - only on one PC !?
By elJorda in forum Blu-ray RippingReplies: 1Last Post: 25th Feb 2009, 04:33 -
RipBot error message
By NormaJ in forum Blu-ray RippingReplies: 3Last Post: 29th Dec 2008, 12:34
Statistics
Newest guides
Latest tool updates
New media comments
