EDIT: I think the motherboard may be picky on what JEDEC timings is supports. I'm unfamiliar with this type of issue.
I'm stumped on what RAM will work with my motherboard. It's a GVC AR862 (Link) which "Supports 2 x 168 pin DIMM sockets, support 32MB minimum and up to 1GB maximum | 32, 64, 128, 256 and 512MB PC 66/100/133 SDRAM/VCM DIMM | and 16, 64, 128 and 256Mbits memory chips". I've tried dozens of 256MB and 512MB sticks which have standard 64x64M configuration some being PC100 or PC133. The only one that doesn't have major stability issues is the original 64MB stick that came with the PC. I'm hoping that somebody can point me in the right direction. I was able to boot up Windows long enough to glean this information from CPU-Z:
Current motherboard configuration
Memory Type SDRAM
Memory Size 576 MBytes
Memory Frequency 100.2 MHz (1:1)
DRAM Interleave 4-way
CAS# latency (CL) 2.0
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 6
Original 64MB module that works:
Memory type SDRAM
Manufacturer (ID) SpecTek Incorporated (7F7FB5FFFFFFFFFF)
Size 64 MBytes
Max bandwidth PC125 (125 MHz)
Part number
Serial number FFFFFFFF
Manufacturing date Week 255/Year 255
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.0-3-3-5-0 @ 83 MHz
JEDEC #2 3.0-4-4-7-0 @ 125 MHz
Example of a tested 512MB stick that does not work:
Memory type SDRAM
Manufacturer (ID) Micron Technology (2CFFFFFFFFFFFFFF)
Size 512 MBytes
Part number 16LSDT6464AG-10EB1
Serial number 1A13C92D
Manufacturing date Week 06/Year 02
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
JEDEC #1 2.0-2-2-5-0 @ 100 MHz
JEDEC #2 3.0-3-3-7-0 @ 125 MHz
Note: Everything in the system has been tested in other PCs and is known to work. The BIOS does not allow for any adjustment to memory settings whatsoever.
Using ram that old is going to be a problem finding any that will work with that system,sounds like the mb is very picky about ram,any reason you need an old design system like that running?
Ben Johnson-I didnt take any stereos!
It's a friend's computer. They don't have the money to buy a new system and would be satisfied if I could get 1GB (2x512MB) to work in it.
some of those old via boards were sensitive to single or double sided memory boards. it's been a long.......... time but i think they needed low density double sided memory boards. check the one that worked and see if there are chips on both sides.
Working = single sided. I have tried so called "high density" 512MB RAM that is single sided but that was just as bad or worse. I think this might have something to do with the JEDEC timings. The one stick that works, which is labeled PC100, supports 83MHz and 125MHz. What's that all about? I could be looking in the wrong direction but I didn't notice any of the other sticks I've tried with those timings. The PC100s were 100/125MHz and PC133 100/133MHz.Originally Posted by aedipuss
well the mb's old enough the capacitors may not be holding voltage at appropriate levels for most ram. the stuff i used in via boards with amd 1.3 athlons was ocz micro bga pc-166, single sided hd. it was engineered for overclocking 133 fsb boards, but would also run at 66, 100 or 133.
Motherboard and RAM Capability
By HotDamn! in forum ComputerReplies: 2Last Post: 8th Jan 2010, 22:32 -
Compatible RAM.
By A Traveller in forum LinuxReplies: 3Last Post: 10th Oct 2009, 10:44 -
PC2100 ram in a motherboard rated for PC2700?
By freebird73717 in forum ComputerReplies: 2Last Post: 18th Jul 2009, 09:23 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 15:54 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 21:25
