I havent used Itunes in a long time I have 250 songs on my ipod when I use itunes it ask if I wanted to install new version I did then connected my ipod. When It came up it was like nothing was shown on my Ipod it shows at bottom that I have 250 songs on it but when I click on device on Itunes page it shows music,videos,photos but dont list anything. I cant add new music and syn it either or it will erase my older music do to it not showing up in my library. Is there away I can get this off and re add it to my library. I even sign in to my itunes acct I figure when I did that it would have stored all the music I have downloaded...What am I doing wrong???? Once I get my music downloaded can I delete it off my PC and just keep it in itunes library????? Hope someone can help. I thought I could clcik the drive that ipod is connected to pull up that no but no go....
no ones has any idea out of 35 views I see
try an apple board or itunes support. mostly video here on videohelp.com, and it's not like your's is a common problem. itunes works for most people.
You never specified what type/generation iPod you have. There is a way. I use Media Monkey for things like this. The files names will be messed up but when you sync it back to iTunes, the names will go back to the original.
Here, have a look:
http://www.mediamonkey.com/support/i...&kbarticleid=3
But there are many other ways to do it also:
http://lifehacker.com/394046/copy-mu...puter-for-free
How to here ... no need to purchase additional software ... just follow instructions
DOes this also work with iPhone/iTouch?Originally Posted by Bjs
delete iphone songs/videos WITHOUT itunes
By angryassdrummer in forum Portable VideoReplies: 13Last Post: 15th Apr 2012, 22:53 -
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
iTunes 8 displaying a few songs with the wrong run time
By Nintendo Fan in forum ComputerReplies: 26Last Post: 8th Jul 2009, 18:34 -
Saving iPod Library
By Jeikobu in forum Portable VideoReplies: 2Last Post: 18th Jun 2009, 16:56 -
Cant Import videos into iTunes library from other folders
By Gangstapimp50 in forum Portable VideoReplies: 1Last Post: 30th Oct 2007, 00:34
