A friend sent me the files to burn a DVD, but I'm encountering a problem I haven't come across before. I'm missing the files VTS_02_0.VOB and VTS_03_0.VOB--but I DO have VTS_02_0.IFO, VTS_02_0.BUP, VTS_03_0.IFO, and VTS_03_0.BUP.
Am I correct in assuming that VTS_02_0.VOB and VTS_03_0.VOB must have existed at some point in order for those .IFO and .BUP files to exist? There are VTS_02_1.VOB and VTS_03_1.VOB files, so I can't just erase the IFO and BUP files, either.
Is there any way to get around this? To create the missing VOBs or something?
Thanks!
Yes ... at some point those vobs existed
No you cannot create vobs ... well from thin air without knowing the original content
Open each vob in question in vlc and see what each contains ... then contact this friend and ask them if what you seen is all there was to be
If not then you'll advise this friend to supply the files to complete this title
If yes ... strip the video and audio from each vob title into separate folders and simply reauthor
I took a look at a random DVD and on mine, the VIDEO_TS.VOB and VOB_02_0.VOB and VOB_03_O.VOB and a few other VOB_0*_0.VOB files are all the same size. I am highly skeptical that this would work, but if you get desperate and your friend is too clueless to help, you could try to copy VIDEO_TS.VOB to the missing files and see if it works. I doubt it will, but I suppose you could try.
VOB_0*_0.VOB are menu vobs... not mandatory. What are you burning with? Are you getting any error message?
Bjs - thanks for that info/confirmation. I don't know how to strip and reauthor, but I'll look into it.
jman98 - Tried that before posting and it didn't work, but thanks!
ChrissyBoy - I'm using DVDShrink to create an .ISO and I get an error message when I try to open the files; it says "Failed to open VOB_02_0.VOB / File is missing."
Here's an explanation as to why you might not want to use DVDShrink to create ISOs:
http://www.digital-digest.com/~bluta...pgcedit_v2.htm
Read the "TECHNICAL INFORMATION ..." section at the bottom.
Some burning programs like Nero may let you create and burn a DVD even with the missing files, but they will bitch about it. ImgBurn is another way to create ISOs and a great program for burning. Don't know if it will let you get away with the missing VOBs or not.
A ripping tool of some kind should let you extract the data from the disc, which you can then re-author. DVDDecrypter should work. DVDFab HD Decrypter may be OK, not sure about the free version though. Ripping the video in IFO mode is generally best as you can configure that to give you one big file for each separate VOB section such as one big file for VOB_01*, another one for VOB_02* and so on.
Ben Johnson-I didnt take any stereos!
Missing ifo
By Kurgan71 in forum SubtitleReplies: 1Last Post: 16th Jun 2009, 01:24 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
how to generate missing ifo file from dvd
By deejay.2001 in forum Authoring (DVD)Replies: 14Last Post: 2nd Jun 2008, 10:53 -
missing ifo-files
By scio_fantasio in forum MacReplies: 5Last Post: 12th Dec 2007, 23:04 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
