VideoHelp.com Forum
    When I first bought VOB2MPG PRO I had trouble getting the video preview to work under Vista.
    Eventually I found it worked ok if I manually turned off Aero.
    It then worked fine until I downloaded the latest build (3.0.0501).
    Now it won't work at all with or without Aero.
    There isn't even a message when you load files saying that Aero is being turned off.
    I tried going back to the previous version but the video preview in that now won't work with or without Aero.
    This is very frustrating and I regretfully will have to dump VOB2MPG if I can't find the problem which is a shame as in other respects it works really well.
    Has anyone out there any idea what the problem could be.
    Cheers
  2. Member ChrissyBoy's Avatar
    I suspect there may be a change in your system - codec wise. Drop me an email and i will send you a build which tries additional options when i comes to the preview.
  1. Video Preview in Vista
    By barlowdog in forum SVCD2DVD & VOB2MPG
    Last Post: 13th Dec 2009, 07:31
  2. Replies: 2
    Last Post: 8th Feb 2008, 20:03
  3. Replies: 0
    Last Post: 27th Jan 2008, 02:48
  4. Vista and Video Capturing Problem...
    By solartaco in forum Capturing
    Last Post: 30th Jul 2007, 12:26
  5. Problem When I Preview
    By VaTo17LoKo in forum Newbie / General discussions
    Last Post: 15th May 2007, 06:36
