DVDauthor solution is attached.
Several titlesets, cell jump commands via root menus, 1/2 sec fake chapters in the beginning and end of each 4:3 and 1:3 title, to enable "seamless" chapter skipping.
g12 register is 1 or 2 depending on where you want to jump - first or last chapter in title.
The only headache is precise chapter (cell) timing, DVDauthor seems to select closest I-frame randomly - any ideas are welcome!
author2.xml
Is there a question somewhere in there?
No question - just sharing a solution
I am assuming this is an attempt to get seamless insertion of 4:3 material from another titleset into a 16:9 title. I don't have an answer, but I foresee several problems.
1. You cannot get seamless play across titlesets. The act of moving between titlesets and seeking the new title takes too long, and precludes a seamless join. You also cannot get seamless chapters across multiple titlesets.
2. You will experience aspect ratio problems with many players if you jump between 16:9 and 4:3 material when trying to make it seem like a single title. There is a reason 4:3 and 16:9 material must be keep in different titlesets.
Yeah....4x3 and 16x 9 assets can't reside in the same VTS so there has to be a non-seamless pause while the players laser heads up into the VMG then back into the 2nd VTS.
All authoring tools wont even let you put both into 1 VTS. Does DVDauthor allow this? If so, Id never be using that tool...ever!
Looking at the XML file the OP posted, the titles are in different titlesets, so there won't be a seamless jump
Solution for burning of DVD
By pboong in forum Authoring (DVD)Replies: 19Last Post: 12th Nov 2010, 09:56 -
What is the best DVD to Xvid (or DIVX) solution?
By Chrushev in forum Newbie / General discussionsReplies: 8Last Post: 19th Jan 2010, 16:11 -
DVD Storage Solution ?
By xobituaryx in forum MediaReplies: 2Last Post: 7th Feb 2009, 23:00 -
New DVD on Demand Solution Launched
By marshyman in forum Latest Video NewsReplies: 0Last Post: 12th Nov 2007, 12:23 -
Need an easy all-in-one DV to DVD solution
By kyroha in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:16
