VideoHelp.com Forum
    When I open my external hard drive via "my computer", I see folders I created, both hidden and un hidden.
    But when I use Nero express to add files and I go to my external, I see these files I have never seen before:
    $RECYCLE.BIN
    folder - System Volume Information
    autorun.inf
    Thumbs.db
    Recycled
    I dont know why there are two recycle bins. Why can't I see these from the regular windows prompt?
  2. Member Soopafresh's Avatar
    Most of those files/folders are normal system files, except for Autorun.inf . You've possibly got a worm/virus.
    Rename or delete autorun.inf and see if gets automatically recreated a few seconds later. If it recreates itself, then you're infected
    See if you've got a folder called Recycler on the root of that drive as well.
    "Quality is cool, but don't forget... Content is King!"
  3. Member T-Fish's Avatar
    dont delete it !
    autorun.inf is only adding the icon to the drive.
    you can open it with notepad and see what it does.
    the rest are system files and they are hidden in your windows explorer because you have the folder options set that way.
    If you want Exporer to show those files disable the "Hide protected operating system files" option.
    You have two recycle bins because windows makes one and you have some other software installed that maintains its own recyle bin -- Norton or some such.
    Thumbs.db is the thumbnail cache that Windows creates when in thumbnail view.
    System Volume Information contains System Restore data.
    How do I display these folders? In folder options, I select to have all hidden folders to display, but I do not see them. The only time I see them is when I use Nero for some reason.
    Try turning OFF the "Hide protected system files" option as well
  1. Software to Get Files from IPOD to external hard drive
    By angryassdrummer in forum Portable Video
    Last Post: 13th Mar 2011, 00:52
  2. external hard drive
    By alintatoc in forum Computer
    Last Post: 26th Sep 2009, 19:54
  3. Copying and converting files to external hard drive
    By soxenme in forum Newbie / General discussions
    Last Post: 25th Feb 2009, 17:16
  4. Store ISO files on an external Hard Drive?
    By Ronny G in forum Newbie / General discussions
    Last Post: 21st May 2008, 07:32
  5. Replies: 17
    Last Post: 24th Nov 2007, 08:47
