Hey all
I cant count how many PC's i have built & repaired, how many PSU's that have went through my hands and i have always seen this plug on the majority of PSU's but i have never had to use it and i have never seen a mobo that used it, until NOW!!
A friend wanted me to see what was wrong with an old PC they wanted to get working, it's an old gateway.
I don't have any old PSU's around anymore that have that plug so i threw in a newer one and have nothing to plug into the mobo for that power.
I booted up the PC and installed windows XP and everything seems to be running fine.
So what is the purpose of that extra power plug on the mobo's ?
old server style aux power to cpu.
you can get these
http://www.cwc-group.com/20atxpoextca.html--
Yeah i was thinking it was for the CPU or the ramm but it all seems to run fine with nothing plugged into it.
The first thing i noticed was the ramm also,
http://support.gateway.com/s/MEMORY/RIMM/5000346/500034601.shtml
http://support.gateway.com/s/MEMORY/RIMM/5000346/5000346nv.shtml
And that stuff gets way hot!!!
Wow... $9.00, i can get a new PSU with the connector on it for $20.00, i just figured if it was running and everything is working maybe i did not need to worry about it.
I suppose i could wire the plug off the old one onto the PSU without it... -
those early p4s drove me to build amd systems for awhile.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
auxiliary power connector on aiw2006?
By greenbag in forum ComputerReplies: 8Last Post: 2nd Sep 2010, 17:37 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
8400 gs 256 mb power connector issues
By hairysac in forum ComputerReplies: 4Last Post: 26th Apr 2008, 22:56 -
What is a pci-e supplemental power connector?
By yoda313 in forum ComputerReplies: 16Last Post: 30th Jan 2008, 18:30
