VideoHelp.com Forum
  1. Hi
    I am ripping my DVD's to my HDD using DVD Decrypter or DVD shrink as single complete VOB's to stream to my PS3. The only issue is that some of the VOB's will allow time searching on the PS3 and others will not. When I press the button on the PS3 to bring up the file details as it's playing, the ones that do not allow time searching show a length of 00:00 where as those that do show a proper length. Yet on the static thumbnail on the PS3 it shows a correct length.
    I've tried ripping various DVD's and some seem to be ok and others not. Does anybody know why this is as it seems like an oddity to me where this info lies in the VOB that some have it and some don't.
    Any help would be great.
    Many Thanks
    Daz
  2. Member hech54's Avatar
    If they are NEW, store bought, Hollywood protected DVDs then you need a new ripper....or two.
  3. Thank you for your insight.
    Daz
  4. Member hech54's Avatar
    DVDFabDecrypter is the newest, still updated ripper. There is a free portion of the program.
  5. Member MOVIEGEEK's Avatar
    I don't think the ripper is the problem, either it rips or it doesn't. Try using FixVTS on the VOB's.
    Does the PS3 support DVD folders(ie IFO,BUP,VOB) or ISO's? If so that might be a better way to go, it usually plays better when IFO's are present.
    Yeah, it sounds like a timestamp problem. If you don't mind spending a bit of money, consider VideoRedo. You can do a full rip of your DVDs and just use VideoRedo to combine the VOBs into one mpg file while running Quick Stream Fix. QSF is their program to fix time stamp issues and it really seems to be the best at doing that. You can download a fully functional trial version to test it out.
  1. Portable Decrypting Software
    By Drazick in forum DVD Ripping
    Last Post: 20th Aug 2010, 17:11
  2. decrypting a dvd with MTR 2.6.6
    By andyx181x in forum Mac
    Last Post: 2nd Dec 2007, 09:05
  3. Errors decrypting dvd
    By Beaker14 in forum Newbie / General discussions
    Last Post: 31st Oct 2007, 10:59
  4. Decrypting Software
    By csaplot in forum Video Conversion
    Last Post: 22nd Jul 2007, 09:54
  5. DVD Decrypter only decrypting 46 minutes of DVDs
    By morphjk in forum DVD Ripping
    Last Post: 21st Jul 2007, 03:26
