VideoHelp.com Forum
  1. A friend gave me some files he created for a DVD - so it's not a protected.
    I want to extract audio from the files in wav format.
    Attached is a screen capture of the files.
    Can I use VirtualDub to do this?
    use dvd audio extractor..great program, easy to use
  3. Member hech54's Avatar
    DVDDecrypter
    IFO Mode
    Demux audio and video
    File Splitting NONE
    Convert audio file to WAV with Goldwave(or similar).
    All Free(I think Goldwave is still free....or shareware).
  4. Originally Posted by tkolt
    This one seems very simple to use. 30 day trial should work just fine too.
    Thanks tkolt
  5. Member t0nee1's Avatar
    Once decrypted/ripped (if using DVDD as suggested) you can import the AC3 audio in Audacity..It even imports VOB(via ffmpeg library)..Thought I'd chime in, since I like your Avatar.. 8)
    http://manual.audacityteam.org/index...#installffmpeg
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
    Open up the files in DGIndex. Go to Audio Output menu and select Decode AC3 track to WAV. File Menu --> Save Project.
    DGIndex Manual
    hmm..2 avatars with the same creepy guy :P
  8. Member KneeGrow's Avatar
    IDK, can you use your legs to cross the street?
    These type of questions should be banned (even though I can't guarantee I haven't asked them myself.)
    I mean, really why not TRY IT OUT and then tell us about your experiences????
    I understand this emotion, being scared or lazy or ??? to try out new things, but still. It's more efficient when you try it out, then tell us what didn't work.
    Of course, it not only just looks better to show us that you made an effort, it just IS better.
    Just let this be your anthem for asking questions on this forum:
    http://www.youtube.com/watch?v=TPFXKDaDkyo
    River Tam: ''Can't look, can't look!'' My old avatar: dress, movies
  1. How to extract audio from .vob files
    By webadm in forum Newbie / General discussions
    Last Post: 16th Jan 2012, 21:28
  2. How to Extract Audio From WMV Files?
    By devilcoelhodog in forum Audio
    Last Post: 23rd Jun 2009, 10:32
  3. Replies: 5
    Last Post: 6th Sep 2008, 18:43
  4. Batch extract audio from multiple DV files?
    By Colmino in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 21st May 2008, 10:55
  5. How can I extract AC3 audio from VOB files?
    By Sean_ve99 in forum Editing
    Last Post: 1st Oct 2007, 04:56
