I have an HP m7250n Media Center. Our cable provider, Comcast, has switched from analog to digital. Now I can only receive the low station numbers (2 - 25) and those have poor quality. I am not sure if the tuner is replacable, and if so, does anybody have a product suggestion that will receive digital and compatible with HP Media Center.
Thank
Bruce
Thread: analog to digital tv tuner
You will have to look for a QAM tuner -- the system that most digital cable systems use. But you will find that most digital channels are encrypted. The ones that aren't are probably the same channels you get now with your analog tuner. If you have an HDTV with a QAM tuner try plugging the cable feed directly into the HDTV (ie, bypass the cable box) and running a digital channel scan. That will give you an idea of what channels are available via clear (unencrypted) QAM.
Basics are unencrypted on comcast, according to some friends that do it. Indeed, you need a QAM tuner.
I suggest this one: http://www.amazon.com/gp/product/B00...SIN=B00138H420Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Assuming you want more than the unencrypted locals, normal solution is to rent a cable box and control it from MCE with IR control. For SD the Hauppauge cards are popular.
HD cable capture is still a mess. The Hauppage HD-PVR is an option.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Analog signalin and Built-in digital TV tuner
By marti252 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Jan 2010, 07:47 -
If I buy a 14 inch SDTV with a digital tuner, can i watch digital programs
By davidsama in forum DVB / HDTVReplies: 3Last Post: 6th Sep 2007, 11:25 -
analog video to digital using digital camcorder and windows movie maker
By bbrule7 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jan 2007, 19:15 -
Analog TV Tuner with Digital Cable Box???
By bambamrl in forum DVB / HDTVReplies: 4Last Post: 17th Dec 2004, 22:20 -
Help capturing analog with with analog-to-digital passthroug
By okorkie in forum CapturingReplies: 6Last Post: 5th Jul 2003, 20:45
Statistics
Newest guides
Latest tool updates
New media comments
