Everytime I've tried converting this clip to ANYTHING I keep getting this
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Thu Jan 14 01:19:33 EST 2010
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 29.97 (30000/1001)
Input #0, asf, from '/Users/brittany/Downloads/kh_ending.wmv':
Duration: 00:10:52.4, start: 3.000000, bitrate: 442 kb/s
Stream #0.0: Audio: wmav2, 44100 Hz, stereo, 64 kb/s
Stream #0.1, 29.97 fps(r): Video: WMV3 / 0x33564D57, 320x240
Incorrect frame rate
Help!!
Thread: Incorrect Framerate?
The version of ffmpeg in ffmpegX doesn't support the WMV3 video codec (Windows Media 9 Standard). This caused ffmpegX to NOT set a default framerate. No framerate at all is always incorrect, heh. Even if you would manually set a framerate, it would still fail because the codec isn't supported.
Newer versions of ffmpeg do support WMV3, so you could try some other converter software based on a newer version of ffmpeg.
I did a conversion with MovieConverter Studio that worked somewhat (result here). (Actually I used a command line conversion with the ffmpeg binary from that app.)
Another possibility is of course Flip4Mac Player Pro, a third-party QuickTime component that allows QuickTime Player Pro to read WMV and export to any other QuickTime format.
Parameter is incorrect
By xstoanurag in forum ComputerReplies: 2Last Post: 16th Jun 2011, 20:43 -
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
mpeg 2 timecode incorrect!!
By DATENSCHUTZ1 in forum Newbie / General discussionsReplies: 4Last Post: 19th Apr 2010, 15:58 -
Parameter Incorrect?
By The Monkees in forum ComputerReplies: 3Last Post: 18th Mar 2010, 17:41 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57
Statistics
Newest guides
Latest tool updates
New media comments
