VideoHelp.com Forum
    I've been trying to write a dvd for the past two days with Encore and the first avi file transcodes fine, the second one for some reason that Encore won't deign to tell me causes it to stop. Is there another format that i can convert the avi's to that might avert this from happening?
    what was the difference between the 2 avi files? use mediainfo (view=>text)
    You could convert to DVD compliant MPEG2 for import , which Encore will not transcode (it will allow pass thru).
    You could use HCEnc for this, but it requires avisynth knowledge. So you could use AVStoDVD , which uses HCEnc and automates & simplifies the process, and just take the asset to import into Encore.
  1. AVCHD to Blu-ray in Adobe Premiere Pro without transcoding ?
    By Gibbus in forum Authoring (Blu-ray)
    Last Post: 6th Nov 2011, 21:47
  2. Adobe Encore
    By mobie29 in forum Authoring (Blu-ray)
    Last Post: 6th Jan 2011, 01:09
  3. Adobe Encore and forced transcoding
    By juantohu in forum Authoring (DVD)
    Last Post: 10th Dec 2009, 01:40
  4. Different Transcoding on Encore
    By htalnts in forum Authoring (DVD)
    Last Post: 14th May 2008, 22:42
  5. Adobe Encore Help
    By Entengdigital in forum Authoring (DVD)
    Last Post: 17th Jan 2008, 02:36
