VideoHelp.com Forum
    I'd like to convert an MKV movie from 25 fps down to 23.976 fps and then make of this AVCHD format so after burning out I would be able to watch on my PS3 and my friend on his BD player. For this purpose I used multiAVCHD program and the result was unsuccessfull (audio to video out of sync). I used tsMuxeRGUI and manually set fps to 24000/1001 but during muxing some error comes on:
    >Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps.<
    I removed audio from my movie and put it again thru tsMuxeR. I've got a video with fps to my liking then but there is a problem for me to mux this non-audio AVCHD with an audio. I googled for this for some time and couldn't find anything. Then I'm taking another approach: I want to change fps right in an MKV before any other procedures using MKVMerge but I don't know what I supposed to put in Timecodes field and how to get those timecodes
    Can I count for some help/advice, please
    Here MediaInfo of the video:
    General
    Complete name : C:\Users\Mark\Documents\Movies 6\Nordwand.mkv
    Format : Matroska
    File size : 5.53 GiB
    Duration : 2h 1mn
    Overall bit rate : 6 537 Kbps
    Encoded date : UTC 2010-01-13 07:44:41
    Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Muxing mode : Container profile=Unknown@4.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 1mn
    Bit rate : 5 958 Kbps
    Nominal bit rate : 5 866 Kbps
    Width : 1 280 pixels
    Height : 544 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 25.000 fps
    Original frame rate : 24.000 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.342
    Stream size : 5.04 GiB (91%)
    Title : Nordwand (En)
    Writing library : x264 core 67 r1130M 8475977
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=5866 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : English
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 2h 1mn
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Video delay : 6s 999ms
    Stream size : 388 MiB (7%)
    Language : English
    BTW: This part sounds messy, doesn't it
  2. Member midders's Avatar
    You can convert between 23.976 and 25 fps using the AssumeFPS command in AVISynth. This changes the framerate without inserting/removing frames so the video will play faster or slower than before; the 4% difference will be overlooked by the viewer. AssumeFPS will also change the audio to match.
    If you're new to AVISynth you'll need the following tools: AVISynth (latest version), ffdshow (and possibly Haali Media Splitter). Your script (myfilm.avs) will look something like:
    DirectShowSource("myfilm.mkv")
    AssumeFPS(2997,125,true)
    You can then use the AVS file as input to whatever converter you want to use.
    Slainte
    midders
    Thanks for the answer. I have to read some about command line now since I've got no clue about it at all.
  4. I'm a Poll Super Moderator johns0's Avatar
    Try uncropmkv and change fps to 23.976.
    Ben Johnson-I didnt take any stereos!
    You can load the specified AVS file into Xvid4PSP and convert it to a h264-encoded MKV or MP4.
  1. Replies: 11
    Last Post: 5th Feb 2011, 14:09
  2. To synchronize 29,970 audio fps for 23.976 fps
    By DruidCtba in forum Newbie / General discussions
    Last Post: 27th Sep 2009, 12:01
  3. Sync 29.970 FPS audio to 23.976 FPS video?
    By LCO1971 in forum Newbie / General discussions
    Last Post: 13th Sep 2008, 15:23
  4. Converting 23.976 fps to 29.9 fps
    By zanos in forum Video Conversion
    Last Post: 13th Apr 2008, 09:03
  5. Difference?? 23,976 pics/s or 29,976 fps
    By twanbaten in forum Authoring (DVD)
    Last Post: 6th Nov 2007, 11:29
