VideoHelp.com Forum
  1. Member EagleW's Avatar
    I am a third time poster. I would very much like to author a Blu-ray disk with menu controls (like a DVD). However I only have SONY Vegas Movie Studio Platinum 9. I can author a Blu-ray disk with the software but it has no menu controls. I was wondering if there is a peice of software that can be used just for that purpose? (fairly cheaply!) I also have Works 4 but it wont recognise the rendered SONY file to import it. Any steer would be appreciated, cheers.
  2. Member vcd4ever's Avatar
    What format is the SONY file rendered to, tmpgenc authoring works 4 only supports MPEG2.
    Vcd4ever.
  3. I'm a Poll Super Moderator johns0's Avatar
    You can use multiavchd to author blu-ray with menus.
    Ben Johnson-I didnt take any stereos!
  4. Member EagleW's Avatar
    Many tanks to 'vcd4ever' when I read your reply the mention that Works 4 only accepted MPEG2 jogged my memory.
    I checked my 'render as' setting and changed it to 'Main Concept MPEG2' encoding and thats fixed my problem. Now Works 4 recognises the rendered file, and the fulley edited 'SONY movie studio platinum' movie can be authored with menus in Works 4. Thanks for taking the time to answer.
  5. I'm a Poll Super Moderator johns0's Avatar
    If your files are avchd to begin with then use multiavchd to author the files cause it wont re-encode them and you keep the original quality.Rendering the files to mpeg2 will lose quality.
  6. Member EagleW's Avatar
    Thanks for your input, however my footage was HDV and as a result was an m2t file. Should have mentioned that earlier, sorry.
  1. Sony Vegas Pro mpeg rendering size larger than movie studio
    By bbbbbbb45 in forum Newbie / General discussions
    Last Post: 17th Jan 2012, 12:31
  2. Rendering Issue with Vegas Movie Studio and GoPro
    By Squid_uk in forum Newbie / General discussions
    Last Post: 29th Nov 2011, 11:13
  3. Whats is best HD option for rendering with Sony vegas movie studio HD?
    By Sevy in forum Newbie / General discussions
    Last Post: 17th Oct 2011, 15:57
  4. Replies: 5
    Last Post: 27th Mar 2011, 17:01
  5. Sony Vegas Movie Studio 10 rendering problem
    By videogirl214 in forum Editing
    Last Post: 18th Aug 2010, 23:29
