Hi,
I have a Sony Vaio that is about 2 years old. Recently the battery that came with it wouldn't hold a charge, so I ordered a new one and made sure it was compatible before buying it. Now I get no power on the laptop with either battery or when using the ac power cord. Any ideas on how to get this working again? I'm not sure if it went into some kinda crazy hibernation as a result of no power for a couple of weeks. I do get a green light on my ac adapter, so I know it has power.
Results 1 to 9 of 9
Sounds to me like maybe the place on the laptop that the power cable connects to has broken in side the laptop...This happened to my daughters Dell B 130 laptop before christmas, cheap fix, but a pain in the ass to replace it...info on the Dell here...Maybe the same thing happened to the Sony
http://www.power-jack-repair.com/Dell.html -
Reinstall old battery and try power up ... if it fires up then the battery you purchased is either defective or not compatible ... circuit wise
Most of these new systems have a circuit designed to check and monitor batteries ... if anything is wrong it will prevent power up
Failing this either the power circuit has failed or the adapter has a fault ... just because the adapters green light is on dose not mean all is well ... few do suffer from shorting in the plug which connects to the unit
You may wish to disassemble the unit and check the power jack for damage ... Sony Vaio VGN-S360P ... power jack replacement
Many more via this link -
Get a multimeter and check your power adapter.
So does the laptop boot at all?
Also the green light on the ac will let you know the cord is working so I would agree with checking the power connection.
Good Luck -
Are there any lights or any indications of power on the Laptop itself? How about before the battery change?
Is the ac adapter connection at the laptop loose? Can you GENTLY wiggle it a bit, while checking for any indicator lights?
Very, very common for this connection to fail. -
Plug the battery off and run your laptop. If it’s running in normal. I think your sony VAIO PCG-FXA47 battery has some problems. Otherwise check if your power wire connect adapter well. Hope it happen or you must take it to the seller or laptop manufacturer service station.
Thanks to everyone for their help. I get no lights at all or anything when plugging it up to ac. I think it maybe needs to have the power jack changed. I will update with any new info once I figure out what the problem definitely is.
Was the battery purchased off of eBay by chance?
I only buy from these guys: http://www.laptopbatterystore.com/
Laptop battery sources
By ranchhand in forum ComputerReplies: 3Last Post: 4th Jan 2012, 06:56 -
Can I power an LCD TV with an external battery?
By Susannah in forum DVB / IPTVReplies: 10Last Post: 9th Nov 2011, 18:50 -
Something wrong with my laptop battery
By aruwin in forum ComputerReplies: 4Last Post: 28th Sep 2011, 02:48 -
Which to use on a Laptop, the Battery or Power Cord
By Moontrash in forum ComputerReplies: 4Last Post: 7th Jun 2010, 19:16 -
laptop battery
By romanstopme in forum ComputerReplies: 7Last Post: 23rd Feb 2009, 03:03
