Hi all.
I'm going to be doing a video production soon, recorded in 720p. I'm building an external hard drive enclosure that has usb and firewire ports, (I'll use firewire), with two 1TB hard drives, Raid 1 for mirroring. There is no networking ability from the enclosure.
All video will eventually come off of a Mac that will be out in the field and be stored on this external hard drive for future editing.
I'm not sure if editing will take place on a Mac or a PC. Probably the Mac, but I'd like the option of at least accessing the files on a Windows 7 Home Premium 64 Bit PC.
I've tried to do some research as to what file allocation table type to use that is compatible between a Mac OS X and Windows 7 Home Premium 64 bit. I see that FAT32 is basically universally compatible all around (but I'd have to pull out my old Windows ME system to create a partition larger than 32MB on the 1TB drives, since 2000 and XP restrict the FAT 32 partition size deliberately to try to force people into NTFS.)
I am aware that there is a 4MB restriction on the file size written to a FAT32 partitioned hard drive, something I want to avoid.
So, my question is, how would I go about ensuring that the external hard drive enclosure is readable by my Windows 7 Home Premium 64 bit system, as well as Mac OS X?
Thanks in advance.
Originally Posted by apollo1980
Pre-requisite questions.
What video format is coming in from the field Mac? What camcorder model number? 720p files will be large so you don't want that on a FAT32 formatted drive.
Why RAID 1? Keep a video backup elsewhere. RAID 1 is not a backup. This is server think.
Why 64 bit on Windows? That constrains your software choice and forces you to ungrade most apps. What is the benefit?
Background issues:
A stock Mac OSX can read a NTFS formatted drive but can't write without third party apps.
A Windows PC can't read a Mac formatted drive without a third party app.
Fat32 is universal but limits file size to 2/4GB depending on software.
A networked Windows or UNIX server can be used by both Mac and Windows but the connection needs to be fast depending on video format being used. Uncompressed 720p gets you into pro video server territory.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
P2 will be the format.Pre-requisite questions.
Once all of the video is done on the mac, I'll need to take it from the photographer, a hired individual, and take it to an editor, another hired individual. So this will be my only copy after I get the footage from the photographer. I'm going raid 1 for a mirrored, redundant backup in case a drive crashes.Why RAID 1? Keep a video backup elsewhere. RAID 1 is not a backup. This is server think.
I have a new computer with windows 7 home premium 64 bit. I may purchase Sony Vegas Professional and edit the project myself. Not sure yet. I also may have an editor do the work for me using a Mac and Final Cut Pro. Even if I go this route, I'd like to be able to access this hard drive enclosure from my PC. Hiring an editor or not comes down to if I have enough money left in the budget to pay him.Why 64 bit on Windows? That constrains your software choice and forces you to ungrade most apps. What is the benefit?
If the footage is shot on a P2 camera, then copied to a MAC, you should have no problems using FAT32. As long as the footage isn't edited first.
P2 cards use FAT32
P2 is a pro flash card. If 720p, the format is likely DVCPro-HD, 1280x720p/50 if "PAL" or 960x720p/59.94 if "NTSC".Originally Posted by apollo1980
DVCPro-HD uses 4x DV codecs resulting in 100Mb/s bit rate or about 50GB per hour. You will max out 32GB in 38 minutes.
I'm not real comfortable trusting your only copy to extended partition FAT32. I'd either get the Mac format reader app for the PC or the NTFS writer app for the Mac.
RAID 1 protects you from a drive failure but not more common data loss like accidental erasure or frame loss during writes. You should buy additional drives for true backup.Originally Posted by apollo1980
Vegas Pro 9 does not support DVCPro-HD. There is a third party app called "Raylight" from DVFilm that adds that capability to Vegas and works well. Premiere Pro CS 4 does support DVCProHD import.Originally Posted by apollo1980
If the project is going to be pre edited in Final Cut Pro on a Mac, they will likely convert DVCProHD to Apple AIC or ProRes422. Once they do that you will have difficulty moving the project to a PC without a recode to uncompressed or Cineform. You really need to think through your work flow so you don't paint yourself into a corner.
Why is the project coming to you via a Mac and not from original P2 cards? You need to specify they deliver the original camera DVCProHD MXF files, not a FCP conversion. Panasonic has a DVCProHD player codec that will allow you to play the files on a PC.
The only "common" edit format would be uncompressed YCbCr but the file size would grow to about 250-300GB per hour. The Mac or PC would need a three or four disk RAID video server to edit uncompressed.Recommends: Kiva.org - Loans that change lives.
Is there software that will allow me to take the external hard drive, formatted by a Mac OS X, and firewire it to my Windows 7 PC and recognize the drive, so I can copy over the files?
MacDrive 8 ~$40Originally Posted by apollo1980
http://www.macosxhints.com/article.p...70502234618295
http://www.amazon.com/dp/B002L7HT7W/...SIN=B002L7HT7W
Make sure they deliver the original Panasonic MXF files, not a Mac conversion.Recommends: Kiva.org - Loans that change lives.
Daisy chain miniDV camera to external firewire drive to PC or ?
By rockitman in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2010, 12:35 -
Problems putting a NEW Drive in an OLD External firewire box?
By phase52001 in forum DVD & Blu-ray WritersReplies: 3Last Post: 30th May 2009, 21:03 -
Some MKVs Will Not Play from FW800 External HDD in Mac, Works in Windows
By encodedprocess83 in forum MacReplies: 1Last Post: 11th Dec 2008, 08:26 -
Why won't MiniDV camcorder pass signal through to external firewire drive?
By KeepItSimple in forum MacReplies: 12Last Post: 24th Oct 2008, 07:49 -
Firewire or usb2.0 for external drive media center recording? esata?
By yoda313 in forum Media Center PC / MediaCentersReplies: 29Last Post: 8th Aug 2008, 19:42
