Hello,
I'm using Roxio's basic VHS to DVD to capture an old VHS tape.
After I have captured the footage in NTSC AVI format, playing it back, the picture looks sort of degraded, as I would expect, however there was music playing and it seems to stretch pitch up and down as it's playing.
I'm trying to figure out if this is something that's caused by:
1. The Tape is too old
2. My VHS player
3. Roxio VHS to DVD
Either way, is there a way to fix this issue? Everything between audio & video that's captured is in sync, but the audio just stretches pitch and in and out at random times.
does it sound like that when you're playing it back from vcr to a tv?
greymalkin - I'm about to test the tape out on a different vcr to determine that.
When I play back the VHS to a TV the audio pitch doesn't change.
Those Roxio VHS to DVD decides are cheap junky little things, it is a possible problem. It might be your choice in capture software/methods, however.
Consider using VirtualDub to capture instead: http://www.digitalfaq.com/guides/vid...virtualdub.htmAnswers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
problem on captured VHS frames
By stefangs in forum CapturingReplies: 13Last Post: 5th Mar 2012, 01:38 -
Remove noise from audio captured from VHS
By arminio in forum RestorationReplies: 8Last Post: 9th Feb 2012, 07:59 -
Question about captured VHS Tapes
By lucgallant in forum CapturingReplies: 5Last Post: 25th Apr 2010, 21:57 -
Should deinterlace VHS captured material ?
By macmithos in forum MacReplies: 16Last Post: 10th Feb 2010, 07:43 -
Captured S-VHS format
By Rinsin in forum CapturingReplies: 24Last Post: 28th May 2009, 12:05
