VideoHelp.com Forum
Results 1 to 10 of 10
    I've created AVI files using VirtualDubMod
    I'm using Riva to create FLV's
    Problem: the files are 2.5 the original avi file size
    If I tweak the settings to make smaller, then my video will be degraded
    What's the best way of keeping the avi as much like the original as possible and making and FLV?
    Also: I've seen in a few places VirtualDub mentioned with FLV
    Can I use it to make FLV's?
    I've done a few searches and all I can fine is info about how to make avi's from FLV's
    Thanks!
    OM
    Nope, virtualdub can't create flv.
    Try instead make a mp4 with h264 video and aac audio using for example handbrake or xvid4psp. You can then get lower file size and keep good quality. And, yes it works FINE with flash!
    But if you want the old flv with the flv codec you can't do much to improve the quality.
    great: i'll try one of those softwares u suggest
    thanks a lot
    tried handbrake and i get a file size of 10mb - the original is 8mb
    that's all weird to me: i thought making an flv, u were degrading and making smaller?
    ok... i tried and it works with mp4's nicecly
    small problem: it won't play unless the WHOLE video has been downloaded
    like the quicktime player
    this sucks!
    is there anything i can do? or do i have to go back to using flv's?
    remux it with mp4box (yamb is the gui) , and it will move the moov atom to the beginning , so it will stream immediately
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Change the bitrate settings to get lower file size. You can even set the desired output file size in handbrake or xvid4sps(under video encoding settings).
    And to get the mp4 to play directly you must change the header in the mp4, xvid4psp does this for you directly, or use MP4 FastStart on the mp4, see http://www.datagoround.com/lab/ .
    edit: Remuxing with yamb works similar as mp4 faststart.
    trying yamb
    this works fast, so quite good
    i didnt want to use xvid4psp because it sounded as though i would get video that was good for psp's - i.e. small
    would u recommend using this as opposed to using handbrake and then yamb?
    let me know what u think
    THANKS
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    xvid4psp maybe was a psp encoder but now it's a very good all-on-one solution that has profiles for most devices and you can adjust all settings manually.
    But handbrake (and then yamb or mp4 faststart) is also another good option, both are based on same h264 encoder so you will get same video quality from both.
    thank u.
  1. FLV audio out of sync, can't work VirtualDub w/ FLV plugin
    By ZantarV in forum Video Conversion
    Last Post: 4th Sep 2009, 11:51
  2. Replies: 7
    Last Post: 31st Mar 2008, 19:23
  3. Encoding for Riva FLV Encoder
    By seven_deuce offsuit in forum Video Conversion
    Last Post: 11th Nov 2007, 03:47
  4. Riva flv encoder and windows movie maker trouble.
    By michigan2101 in forum Video Conversion
    Last Post: 29th Aug 2007, 22:23
  5. Riva FLV Encoder 2.0 Problems
    By link2009 in forum Newbie / General discussions
    Last Post: 14th Jun 2007, 12:16
