Right now, I have a Toshiba Tecra A8. I also hae a regular Xbox 360, and a Dazzle DVD Recorder.
I have been told that my computer is too slow/crappy for high quality capture cards, but I would really like some input from "experts." I want the highest quality capture card, in terms of video resolution, that I can get, keeping in mind my crappy computer.
Price is not really an issue, but I don't mind having cheaper options. If I have not been precise enough, please ask me questions about my equipment, and I will answer them to the best of my ability. I am not exactly tech-saavy, but I am not technologically impaired, either.
Thank you for all of your time in advance!
Results 1 to 9 of 9
There are many options for 720x480 DVD resolution.
For high definition there are very few, maybe one for that laptop.
The Hauppauge HD-PVR loops HD analog component 720p or 1080i to an HDTV. It hardware encodes to h.264. The issue will be whether your laptop can play the file smoothly. The A8 specs come up a bit short.
Try to get some HD-PVR sample files to test your laptop.
Other options come down to capturing external from your laptop and encoding to a format the laptop will play.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
If your laptop have ExpressCard interface then Matrox MXO2 may be an alternative for high definition resolution:
http://www.matrox.com/video/en/products/mxo2_mini/
use a decent HDMI capture card like Blackmagic Design Intensity or Intensity Pro
Black magic? Not with a notebook...
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
@edDV - Where might I find sample files to test on my laptop?
Try Google.Originally Posted by FinalGypsy
Maybe someone here can post one. I don't have an HD-PVR. I tested one once but can't find the files.Recommends: Kiva.org - Loans that change lives.
I Googled "HD-PVR sample file" and found this first.
There's a short file linked at the bottom of this page. Try to find a few more.
http://forums.snapstream.com/vb/beyo...-hd-pvr-5.html
It plays jerky in my Athlon 64 dual core notebook using VLC. It plays fine in my Core2 desktop.
yep, but cheap desktop can be cheaper alternative to high bandwidth capture than pure portable/notebook like solutions - i'm not sure that portability is a key on this - if it is "absolutely must" then skip my advice, if not - think on more reliable and cheaper solution - desktop + HDMI cardOriginally Posted by neomaine
portable solutions are always compromise (more expensive and less features than non portable)
(assume that XBOX is not very portable so desktop is a valid alternative)
xbox 360 capture card?
By blindman96 in forum CapturingReplies: 7Last Post: 26th Mar 2011, 20:56 -
Xbox 360 Capture Card
By 23000 Empire in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2010, 08:51 -
Capture Card xbox 360
By Mastapka53 in forum CapturingReplies: 2Last Post: 27th Mar 2010, 13:50 -
By Dr Awesome in forum CapturingReplies: 2Last Post: 19th Feb 2010, 05:06 -
Best capture card for xbox 360?
By Edward1982 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2009, 15:53
