Hi people
I got a problem playing back a 1080P mkv file. I get sound but no video in Zoomplayer, WMP11 and MPC.
This is only for 1080P movie, my 720P MKV's and AVIs work fine. I tested this file on my laptop and it works fine so it is not a corrupted file. Anyone help?
Cheers
Results 1 to 16 of 16
Thread: 1080P MKV playback issue
just checked and its using MP4 AVC same as my other 720P MKV files and they play fine.
AUDIO codec not VIDEO codec.
oops sorry I made mistake in my original post, was meant to say I get audio but no video.
Then you need a h.264/AVC decoder. If you update to MPCHC it has one built in. You might have to manually enable it:
View -> Options -> Internal Filters -> Transform Filters (box on right)... Enable H264/AVC (DXVA) or H264/AVC (ffmpeg). Double click on the latter and set the Decoding Thread Number to 4.
If you want a DirectShow decoder download the 64 bit version of ffdshow and enable it's h.264 decoder.
Then my guess is you're using DXVA and those two files aren't DXVA compliant. Turn off the DXVA h.264 decoder in MPCHC.
Did you exit MPCHC and restart it after changing the settings? The changes don't take effect until the next time the player is started. Also try enabling/disabling the internal MKV source filter.
If none of that works try using different output modules:
View -> Options -> Playback -> Output -> DirectShow Video...
Yes done all of that.
With external filters the file plays but as before just get sound and no video. While with internal filters I get nothing, file dont even start.
I tried both 64bit and 32bit versions of MPCHC
I would purchase the CoreAVC codec for x264 media.
It's $10.
If you have a newer nVidia card it will utilize GPU acceleration for playback.
Try Mkvmerge and mux it again into another MKV file.
If after you load the problem 1080p.mkv file into Mkvmerge, and Mkvmerge does not know what the video stream is, there is a problem with the file. If you do see video and audio tracks, go ahead and make a new mkv file with Mkvmerge. Try the new mkv file.
You can also try muxing only the video with no sound and see if it will play.
Jerry
I use CoreAVC for zoomplayer and same issue with that.
I tried to remux it and extract just video and same issue. Video dont show.
This is annoying me...thanks for the help so far guys.
Just for chuckles you may want to try Splash Lite. If your video card is supported it optionally uses the GPU to play .mkv and .mp4 files. It's the only player I've tried so far where advancing the slider in an .mkv video never crashes.Originally Posted by nekromantik
http://mirillis.com/download.php?fil..._2_0_setup.exehttp://www.FavesSoft.com
"I don't want to belong to any club that would have me as a member."
- Groucho Marx
1080p MKV Choppy Playback - Solved!
By sdbyrd in forum Software PlayingReplies: 4Last Post: 11th Oct 2011, 04:35 -
1080p MKV playback using MPCHC
By pb_cruisader in forum Newbie / General discussionsReplies: 10Last Post: 29th Jan 2010, 13:57 -
1080P Playback On My PC? And WD 1080p Player Need A Expert!
By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 13:43 -
Slow MKV 1080p Playback!
By The_WRATH in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 14:50 -
1080p mkv to 720p mkv?
By nick101181 in forum Video ConversionReplies: 1Last Post: 1st Jan 2008, 15:04
