When burning DVDs using Nero 7, the processes terminates at 93% done. The log from the last crash is listed at the end of this e-mail. I'm connecting to a HP Pavilion DV6000 (which until recently was burning DVDs with no problems--hence, the external burner), Vista Home Premium SP2, 2GB RAM, 140GB hard drive. I'm planning to purchase a desktop in the near future for DVD burning sometime in the near future. I'm just not quite ready yet.
Thanks for any help you can give.
Log:
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.7.5.1
Internal Version: 7, 7, 5, 1
Recorder: <HP DVD Writer 1040d> Version: EH24 - HA 1 TA 1 - 7.7.5.1
Adapter driver: <USB 2.0> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <TSSTcorp CDDVDW TS-L632H >Version: HS02 - HA 1 TA 0 - 7.7.5.1
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
: ST9160821AS 3.BH nvstor32 Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CDDVDW TS-L632H E: CDRom0
HP DVD Writer 1040d F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1981MB (2029436kB)
Free physical memory: 1140MB (1167372kB)
Memory in use : 42 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.1.2010
UDF/ISO compilation
7:23:14 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
7:23:15 PM #2 Phase 112 File dlgbrnst.cpp, Line 1760
DVD-Video files reallocation started
7:23:15 PM #3 Phase 114 File dlgbrnst.cpp, Line 1760
DVD-Video files reallocation completed (no file modified)
7:23:15 PM #4 Text 0 File Isodoc.cpp, Line 6527
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
7:23:15 PM #5 Phase 111 File dlgbrnst.cpp, Line 1760
DVD-Video files sorted
7:23:15 PM #6 ISO9660GEN -11 File Geniso.cpp, Line 3334
First writeable address = 0 (0x00000000)
7:23:15 PM #7 ISO9660GEN -11 File Geniso.cpp, Line 3334
7:23:15 PM #8 Text 0 File Burncd.cpp, Line 3465
Turn on Disc-At-Once, using DVD media
7:23:37 PM #9 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
7:23:37 PM #10 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
7:23:37 PM #11 Text 0 File DlgWaitCD.cpp, Line 2912
Recorder: HP DVD Writer 1040d, Media type: DVD-R
Disc Manufacturer: SONY16 - D1
Disc Application Code: 64, Disc Physical Code: 193
7:23:37 PM #12 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD R/RW, DVD R DL, DVD-RAM.)
7:23:37 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 823
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [F: HP DVD Writer 1040d]
7:23:37 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1026
Prepare [F: HP DVD Writer 1040d] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2286128 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2286128 | 0 | 0x00
2286128 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
7:23:37 PM #15 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
7:23:37 PM #16 Phase 24 File dlgbrnst.cpp, Line 1760
Caching of files started
7:23:37 PM #17 Text 0 File Burncd.cpp, Line 4298
Cache writing successful.
7:23:37 PM #18 Phase 25 File dlgbrnst.cpp, Line 1760
Caching of files completed
7:23:37 PM #19 Phase 36 File dlgbrnst.cpp, Line 1760
Burn process started at 20x (27,700 KB/s)
7:23:37 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2764
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:23:37 PM #21 Text 0 File DVDR.cpp, Line 3070
Recording mode: Sequential Recording Mode
7:23:37 PM #22 Text 0 File DVDR.cpp, Line 3226
Start write address at LBA 0
DVD high compatibility mode: Yes
7:23:37 PM #23 Text 0 File Cdrdrv.cpp, Line 9288
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
7:24:08 PM #24 Text 0 File Cdrdrv.cpp, Line 1303
19:24:08.629 - F: HP DVD Writer 1040d : Queue again later
7:28:49 PM #25 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 1F 18 60 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x2b054000: Len x10000
0x00 00 01 BA 44 A5 9D 7D 3D BF 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 6A 24 B0 A4 77 D0 D0 58 76
0x3D C2 E9 AC E5 C9 AB BC 9F 74 F8 32 A4 EB A0 C4
7:28:49 PM #26 CDR -1135 File Writer.cpp, Line 301
Write error
7:28:49 PM #27 Text 0 File DVDR.cpp, Line 3446
EndDAO: Last written address was 2037855
7:28:50 PM #28 Phase 38 File dlgbrnst.cpp, Line 1760
Burn process failed at 20x (27,700 KB/s)
7:28:50 PM #29 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
7:28:52 PM #30 Text 0 File Cdrdrv.cpp, Line 10529
DriveLocker: UnLockVolume completed
7:28:52 PM #31 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Thread: HP dvd1040 DVD Burnet
CindyLuB8,
The first thing that jumps out at me is that you were trying to burn over usb at 20x, but since the drive says it was a media error, let's go with that as the primary reason for the burn failure.
Since you probably have more of those blanks to work with, you could try slowing the burn down...say, to 8x (just to rule out other problems). However, if you take a look at this page, you'll see that some people can burn that media...and some can't. If you can't get a good burn at 8x, then the odds are your system just isn't going to work with that media. If that's case, using Verbatim or Taiyo Yuden disks would be the most likely solution to your problem.
I see this was your first post here, so welcome to VideoHelp.
Thank you for solving my problem!
CindyLuB8 - you might also edit your original post to remove what might be a software serial key (Windows' key?), underneath the "Hewlett-Packard" line. Even if it's incomplete (is it?), it's still better just to remove all of it.
Thank you. I did remove the information.
