VideoHelp.com Forum
    Hello
    Im new to DVD backup and I want a program that is:
    -Easy to use (basiclly a few clicks)
    -Removes Region Code so it be played on anything
    -Subtitles/Languages
    So far what I ran across to are:
    DVD Cloner http://dvd-copy-software-review.topt...er-review.html
    DVD Shrink
    Jesus, just how lazy are you?
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  3. Mod Neophyte Super Moderator redwudz's Avatar
    AnyDVD and DVDFab HD Decrypter are probably the most popular ripping programs around here. I use AnyDVD>DVDShrink>Imgburn for DVD backup. They only require a few clicks. Shrink by itself will rip most older DVDs. For newer ones, you need a up to date ripper. A few other rippers in our 'Tools' section: http://www.videohelp.com/tools/secti...rs-dvd-rippers
    And welcome to our forums.
  4. Member hech54's Avatar
    No it won't play on "anything". Removing the region code does not change
    the video format and American NTSC equipment doe NOT play well with
    the rest of the world's PAL format.
  5. Member santino_avi's Avatar
    I have used DVD Fab exclusively. Used both the free and paid version.
    I would recommend the free version until you get used to backing up DVD's, as there is no need to pay before you really know what you are doing.
    I use DVD Fab/ DVDShrink/ Imgburn and have backed up my entire DVD collection with a 99% success rate.
    There are some great guides out there. Just do a search for DVDShrink and you will find several guides.
    Good luck!
  1. ripping my dvds collection to hard drives the easiest way
    By angryassdrummer in forum Video Streaming
    Last Post: 5th Apr 2011, 06:07
  2. Easiest Cutting Program?
    By Merkaba188 in forum Editing
    Last Post: 4th Nov 2009, 21:25
  3. Replies: 7
    Last Post: 11th Sep 2009, 21:27
  4. Replies: 2
    Last Post: 22nd May 2009, 16:52
  5. Easiest and fastest ripping prog?
    By Valioser in forum DVD Ripping
    Last Post: 5th Mar 2009, 17:57
