I have 4 Canon HV20 HD camcorders and a 17" MacBook Pro with Final Cut Pro. What additional equipment and/or software do I need to be able to record each channel (from post processing) and mix for a live event from multiple view angles and display it on a projector. Also it needs to be portable so equipment should be Firewire or USB.
At the lower end, Datavideo makes a line of digital switchers that will do what you want. This one switches DV, S-Video or analog component and includes two TBC/Frame syncs. You can spend much more for higher end brands.
http://www.google.com/products?hl=en...ed=0CC0QrQQwAw
You can rent these in some markets.
HDV recording should be done in the cameras for post transfer. A MacBook can't reliably handle recording four live HDV Firewire streams. A MacPro tower (or tower PC) with multiple Firewire cards and multiple drives could.
I'd record either the swiched feed or the wide cover shot to the MacBook for backup. Keep in mind that firewire cables can only run about 15 feet (4.5 meters) without a repeater. For some cameras you may need to run S-Video for the projector switcher.
Pros would use SDI feeds which can run several hundred feet to SDI digital switchers.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
DataVideo have 10m and 20m firewire cables. For HD content you need many, many $.
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum CapturingReplies: 4Last Post: 19th May 2011, 02:41 -
Multiple questions about HD video capture (broadcast, Happauge, Tivo)
By jpt85 in forum DVB / HDTVReplies: 36Last Post: 13th Apr 2011, 19:02 -
How to broadcast a live satellite TV by Adobe Flash Media Live Encoder
By mrweb in forum Video StreamingReplies: 0Last Post: 19th Aug 2010, 20:08 -
My new capture card can record and playback, but won't live stream. :-/
By Deadlight7 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2010, 23:50 -
Mix full d1 and broadcast d1 DvdLab Pro 2
By subba in forum Authoring (DVD)Replies: 12Last Post: 29th Oct 2008, 07:03
Statistics
Newest guides
Latest tool updates
New media comments
