Hi everyone!
Could anyone tell me how to make a perfect copy of a DVD9 movie without changing anything (I'd like to keep the menu etc.)?
I've tried it several ways, but kept failing.
First I copied the files from the original DVD to my HDD (simply ctrl+c, ctrl+v), then burned by Nero as Video DVD.
Then I tried DVDShrink, checked every single tracks to keep, but in the end my DVD player (Panasonic DMR-E55 if it helps) still can't play it.
(PS: I wrote it on a DVD-RDL disk, is this the problem??)
Thread: DVD9 to DVD9 1:1 Copy
Well first off if its a original, its encrypted, so you need something like dvdfab decrypter or anydvd to break the encryption and to put the data on your hard drive, then i would just burn it back to a dual layer with nero of any other burning program, dvdshrink will break the dual layer layer switch, don't use it for dual layers. I've only used dvd+r dl for 1:1 backups, they seem to be most compatible.
Best of luck,
TedTalk nerdy to me
DVDFab Decrypter or AnyDVD are recommended because some DVDs use newer anti-disc copying methods that older decrypters like DVD Decrypter don't understand. Basically you want to rip to ISO if possible and burn with ImgBurn (forget Nero - just causes problems). And use ONLY Verbatim DVD+R DL discs or you will post here crying about why your burns aren't working.
Please check the guides section. I would expect us to have guides on how to do what you want.
Thanks guys! Then I'll try it with one of those progs and a DVD+R DL disc. My only question is why Verbatim?
They are the only ones that don't suck. Not all blank discs are created equal.Originally Posted by Lastman369
Memorsux for example.
Originally a member since 2001, LONG LIVE TARAN's!!!
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
How do I burn a 1:1 copy of a Blu-Ray rip DVD5 or DVD9? AND...
By hakoreh in forum Blu-ray RippingReplies: 8Last Post: 13th Mar 2010, 17:31 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
Can I copy a DVD9 to a DVD4??
By hzgg2 in forum DVD RippingReplies: 1Last Post: 10th Oct 2008, 14:56 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
