VideoHelp.com Forum
    I have ripped several BluRay movies to my HD and started Handbrake to shrink them. I select the source, destination locations and file type (MKV) and then the start button. A DOS window pops up and says: "Encoding: task 1 of 2, 6.25 % " and hangs up. I have uninstalled & re-installed the program to no avail.
    I'm running XP Pro with all current updates, Intel Core2 Quad Q9550 @ 2.83, 2 internal HD's totaling 1.5tb, 3gb ram. I can watch the movies on my computer but would like to shrink them for backup to dual layer dVD's.
    Thanks in advance for any ideas and assistance.
    blacksheep3
    Ripped as what ? A blu-ray folder with m2ts files? or a mkv or some other format?
    If you have a blu-ray folder then would probably Ripbot264 be a better solution than handbrake.
    Sorry about that, I used MAKEMKV and ripped to mkv files. I believe I'm experiencing a computer glitch as now the program(HANDBRAKE) won't even load. When I click on the HANBRAKE icon I get a windows message that says: "Handbrake has encountered a problem and needs to close." The error signature is:
    Event type: clr20r3 P1:handbrake.exe P2:0.9.4.0 P3: 4b0c5409 P4: mscorlib P5: 2.0.0.0 P6:492b834a P7:1b2a P8:c P9ystem.io.filnotfoundexception.
    I did have a computer problem! I reloaded OS and Handbrake is working.
  1. No MS-DOS sound in Current set-up
    By Frank-0-Video in forum Computer
    Last Post: 9th Jun 2011, 08:16
  2. Replies: 24
    Last Post: 1st Apr 2011, 15:49
  3. MPEG1 -> MP3 conversion possible in DOS?
    By Figge in forum Video Conversion
    Last Post: 25th Mar 2009, 08:05
  4. DOS multiplexing for DivX and/or other MPG?
    Last Post: 25th Mar 2009, 02:55
  5. Question about certain dos commands
    By jimdagys in forum Computer
    Last Post: 15th Oct 2008, 22:57
