VideoHelp.com Forum
    I need to convert ISO to AVI/Divc/MPEG with a file size for 700mb or 1 gig. Is there a pay program out there that will do this? I currently convert my dvd with DVD Fad Platinum. I have tried Fair Use, but it was entirely to slow. On average I can rip a dvd to hd in 30min.
  2. Member midders's Avatar
    In a nutshell, buying some software will not help you speed up the process.
    Assuming your ISO files are DVD Video images, then converting to 700Mb DivX at reasonable quality is a slow process. The framesize will need to be reduced and each frame built and re-encoded twice (two pass VBR). With my ageing PC, this can take anything from 6 to 15 hours, though the upper end tends to be when using HD sources. The CPU is the limiting factor (billions of floating point calculations) so use a modern PC with multi-core CPU and an app that supports multi-threading. Going 64bit might help also.
    A 700mb mpg file of a standard length film would have pretty naff quality, unless you use a very small framesize.
    Slainte
    midders
  1. Batch Convert - ISO/DVD to MP4
    By joepic in forum Video Conversion
    Last Post: 8th Feb 2012, 01:40
  2. Batch convert ISO's to video files
    By Nucleus in forum Video Conversion
    Last Post: 13th Nov 2011, 12:50
  3. Convert Divx to Xvid batch
    By nick7461 in forum Video Conversion
    Last Post: 1st Oct 2011, 09:23
  4. VOB to Divx (AVI) - batch convert
    By joepic in forum DVD Ripping
    Last Post: 26th Jan 2009, 00:11
  5. Best Batch convert tool for WMV to DIVX
    By hsantos in forum Video Conversion
    Last Post: 28th May 2007, 08:48
